First post, by g_nome
I have a Clarion Dos Program that have to open with 199 open files set (Not the default 40 settings given by Windows XP. I've set it in the Windows XP's "config.nt" file.
Where can I set it in DOSBox?
* I have to open the program with a command: c:\kbs\chain.com kb.exe
and can't get it to work under Windows XP's DOS Command Window, it works in DOSBox 😀
Thank You!
