First post, by Bruno128
Runs Windows Me and specializes on features like Glide and Sensaura 3DPA while retaining compatibility with late DOS titles. Targeted games: 1995 – 1999.
Highlight parts:
  • Pentium III 1.0EB
  • Soltek 65FVB
  • 128MB Mosel Vitelic PC133 CL2
  • PowerColor EvilKing IV TV CV350 (Voodoo 4 4500 AGP)
  • Turtle Beach Santa Cruz
  • Creative SB16 IDE (CT2290) + Serdaco DreamBlaster S2
  • Adaptec AVA-2904 SCSI
  • Teac CD-540E
  • Teac FD-235HF
Misc parts:
  • 16GB SSD SATA DOM + IDE adaptor
  • LC-Power LC6550M Gold
The attachment Year 2000 build front july 2024.JPG is no longer available
The attachment sandra memory interleave 693a.jpg is no longer available
SBEMU compatibility reports list | Navigation thread
Reply 1 of 9, by mln
Nice build.
I believe it's hard to get a case like this, in good condition, nowadays.
Do you have any pics of the inside?
Why VIA?
Reply 2 of 9, by Joseph_Joestar
Interesting sound card choice with the Santa Cruz. Sensaura is underrated, and can deliver some pretty good positional audio in games like Unreal Tournament.
Can you test if A3D 2.0 can be enabled in Quake 3 (version 1.17) or Voyager: Elite Force on that card? It didn't work on my Yamaha YMF744, which also uses Sensaura, albeit an older version.
Reply 3 of 9, by Bruno128
Thanks for the reactions, I'll take a look.
Noting that I just completed a Deus Ex playthrough on this PC. With h/w 3D audio, 1024x768 high detail, 2x RGSSAA Glide. Had no performance/stability problems.
Reply 4 of 9, by Bruno128
Joseph_Joestar wrote on 2024-07-12, 16:03:
A3D 2.0 in Quake 3 on Turtle Beach Santa Cruz didn't work. WDM driver ver.4193.
s_enable_a3d
Initializing Aureal A3D...
failed
Shutting down A3D...ok
Initializing DirectSound
locked hardware. ok
I used the occasion to benchmark Voodoo 4 in Quake 3 Arena 1.16n. 1024x768x16 high detail, max texture detail, 2x RGSSAA.
timedemo demo001 scores 28.1 fps which is too little for competitive game. One must either disable anti-aliasing or lax detail/resolution.
Reply 5 of 9, by Joseph_Joestar
Bruno128 wrote on 2024-07-16, 16:37:
Thanks for checking this.
Sensaura still sounds pretty good in A3D 1.0 games, but I guess A3D 2.0 support was too much to hope for.
Reply 6 of 9, by Shponglefan
Joseph_Joestar wrote on 2024-07-16, 17:19:
Isn't A3D 2.0 only supported by the AU8830 chip?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 7 of 9, by Joseph_Joestar
Shponglefan wrote on 2024-07-16, 18:25:
Officially, yes. But Sensaura has "Chaotic Wavetracing" which could technically emulate some aspects of A3D 2.0 if both the game and the driver support it. This may need some driver hacking/mixing though.
There a bit more info here: Best Sensaura Implementation
Reply 8 of 9, by ux-3
mln wrote on 2024-07-12, 15:49:
I do actually have a somewhat similar case, no yellowing. But as I don't like beige, I have moved the contents to something black.
I plan to put the old case up on ebay (in Europe) later this year.
It has one floppy bay like this, where you hide the drive behind the case front. It also offers one more 3.5 and one more 5.25 ext. bay.
The extra 3.5 bay is nice for a card reader or some such.
It actually housed quite a similar project:
P3 1000@100fsb (on a slotket)
Asus P3B-F rev1.04 (2xISA)
256 MB ram
SB AWE32 CT-3980 & NEC XR wavetable
Voodoo 5 5500 AGP
VIA USB 2.0 PCI card
Intel Postville 80 GB SSD (with ebay sata-ide converter)
Plextor DVD+R
beige USB 3.5 multi card reader (removed after noticing the performance drop and getting nusb to work).
Retro PC warning: The things you own end up owning you.
Reply 9 of 9, by Bruno128
Why VIA?
Hi thanks for the reaction. Today I added hardware monitoring with 2 NTC probes screwed to CPU and GPU heatsinks. The small display on the back side of the computer is powered from 12V fan header. So if the PC is in standby it's off.
The attachment Year 2000 build inside july 2024.jpg is no longer available
The attachment Year 2000 build sensor july 2024.jpg is no longer available
As to VIA Apollo choice the bad reputation stems (in part) from cheap junk models where it was used. I fully recapped the board (Nichicon LXZ), updated it to latest BIOS and want to see how it actually is in the long run. So far so good.
