First post, by Brosopholes
I will update this main thread with my progress and any verified information I get from you helpful folks.
Hello! Very excited to join this board. I have been building retro machines for a while, but I am in the process of trying to build my ultimate retro windows machine. My main focus is on reliability - I would like to minimize the time troubleshooting in the future and not worry about starting over. I have searched SSD information through the forums and youtube, but the content is disjointed and contested. I'd appreciate any help sorting out the build and answering questions.
Hardware:
IcyDock MB324 Drive Cage (5.25" Drive Bay with 4x SSD)
https://web.archive.org/web/20230602162603/ht … product_72.html
Silicon Image SIL3112 Dual Channel SATA RAID Controller (4 Sata Ports)
https://web.archive.org/web/20240603114218/ht … &product_id=865
Patriot P220 SSDs
https://web.archive.org/web/20240518153208/ht … ata-iii-2-5-ssd
Drive Configuration
• 1x 128gb SSD (DOS 6.22)
• 1x 128gb SSD (Win 3.1)
• 1x 128gb SSD (Win 98)
• 1x 512gb SSD (Game installers, backups, music/videos, etc)
Fixes:
• SSDs will be formatted FAT32 in windows 10
• SSDs will need to be “aligned” in windows 10 - See Software section
• SSDs will be formatted for 96gb (384gb) to allow 25% SSD always free
Software
AOMEI Partition Assistant
https://web.archive.org/web/20230323055249/ht … PAssist_Std.exe
MiniTool Partition Wizard (Attached)
https://web.archive.org/web/20240715225943/ht … tionwizard.com/
Questions:
• Do I align the SSD before OS installs? After OS installs? After games/drivers/OS installs? Periodically?
• Do I need to apply any patches or fixes for older OS to install on large SSD
• Is 25% unused SSD enough to combat the garbage collection issue that wears out SSD?
• Any issues using the 512gb SSD between all OS? Will it need special partitions?
• Can any games be installed on the 512gb SSD and work in all OS?
• Any MBR issues with this setup if only one OS drive is on at a time?
• Does the P220 have onboard trim? Do I have to worry about throughput in win98? Reliability issues from trim onboard vs no trim?
• Any other software to look at to format/align/trim the drives?
• Are there any other fixes that should be applied to make this build ultra reliable?
Working Steps
TBD
Reply 1 of 6, by Ryccardo
Just the easy ones:
Brosopholes wrote on 2024-07-22, 16:43:
Before, as that's a choice you (or your partitioning software) makes when creating partitions 😀
(You may or may not be able to move them afterwards: finding something that does that for FAT16/32 isn't hard - like gParted Live - but easier and faster to do it right the first time!)
Unless you want period-accurately-sized partitions yes, as classic DOS is limited by Int13 CHS access (and FAT16) while 98 is by LBA28;
I guess you could use PC-DOS 7.1.01 or FreeDOS (the ones with Int13X = LBA and FAT32 support), while 98 had a patch made by the famous Rudolph Loew
No such thing as "onboard" trim (at least on most every commercially available SSD) - that's how an OS tells the drive which sectors are not in use anymore, so the only real alternative would be the drive's firmware being aware of whatever partitioning scheme and filesystems you're using on it (which has actually been done for MBR/1 partition/FAT32, though for rather different reasons: Wi-Fi+SD cards like Eye-Fi and FlashAir, and some weird flash drive with an E-Ink capacity display)
What's real (and probably extremely common on any SSD made in the last 10 years, as opposed to a 2004 flash drive or memory card by the lowest bidder) is that drives can still do wear leveling (redistributing writes around the physical sectors) even without TRIM (which doesn't have to be done in real time when deleting something: you could simply boot Linux and run `fstrim' every now and then), and overprovisioning (reserving some capacity, ie trimming some space - as it is out of the box - and not using it anymore, for example by not filling it with partitions) does leave more freedom to the wear leveling logic (25% would be quite a lot, but would also leave you a lot of peace of mind if you "forget to trim" in quite a while - which BTW isn't an issue of time but of sectors allocated and freed)
Is it actually 128 GB? While certainly possible (= not everyone does the following), some consumer brands/models are already overprovisioned at the firmware level, which is how you can buy 120/240/480GB SSDs 😀
Dedicating a physical disk for every OS is by far the most reliable way to avoid conflicts 😀
However you must be aware that in a BIOS system, only Int13 hard drive 80 (and floppy drive 0 - the first of either group) are bootable, so if your firmware is new enough to support booting from "D:" or even have a list-based boot sequence, that will renumber the drives to make the selected one 80, and in all these DOS-derived OSes you will definitely notice that! (drive letters changing, but also the installers for said OSes and fdisk /mbr really insisting on putting the bootloader somewhere on drive 80)
Reply 2 of 6, by Shponglefan
When I did my multi-OS Pentium 4 (see signature link), I used BootIt BareMetal. It functions as both a partition manager and boot manager. It can do things like partition alignment, moving and resizing partitions, etc. I was able to install eight operating systems onto only two SSD drives.
In your set up, it looks like you're planning to use individual SSD drives for each OS? For DOS and Windows 3.11, this seems like a waste. For example, DOS 6.22 has an 8 GB total drive limit (2 GB FAT16 partitions). Since Windows 3.11 runs on DOS, I imagine it would have the same limitation.
The alternative as mention above would be to use a different version of DOS allowing for larger drive sizes.
If you wanted to stay with period-correct OS and drive limits, you could fit DOS, Win 3.11 and Win 98 all on one SSD, each with its own partition.
Similarly, Windows 98 has a 128 GB drive size limit. I'm not sure what the exact intent of the 512GB drive is, but you'd need to install a patch to allow Windows 98 to properly work with it.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 3 of 6, by Brosopholes
I cannot install the SSDs until the SATA Controller arrives. In the mean time, I do have two hard disks in the machine.
Here are the boot options on the BIOS:
The attachment WIN_20240722_13_34_40_Pro.jpg is no longer available
Here is the Hard Drive menu expanded:
The attachment WIN_20240722_13_32_46_Pro.jpg is no longer available
The way I read this, if no CD or removable media is inserted, it will go down the list of devices in the Hard Drive section. When the SSDs are in, and are physically powered off via IcyDock, that list may change on each boot. However, if only the OS have an MBR, and the 512gb does not, I think I will be okay? The (PM) and (PS) at the end of the Hard Drive list may also give clues, but I do not know what they mean.
Thanks for all the inputs 😀
Reply 4 of 6, by Brosopholes
Shponglefan wrote on 2024-07-22, 20:19:
When I did my multi-OS Pentium 4 (see signature link), I used BootIt BareMetal. It functions as both a partition manager and bo […]
I am going to look into that software now! That sounds like a great option.
For reliability, I want to split the OS on independent drives. If I do something stupid, replacing the image will be easy and I do not impact the other OS. The drives were ~ $12 USD, worth the peace of mind and probably the cheapest part of the build anyways 😀
The 512 gb is just hosting media files, backups, and installer files. I would like to be able to access the drive from each OS. With the limits in 3.1 and DOS, it sounds like I would need to partition it 2 times, one 8gb and the rest for win98. Does anyone know a workaround to see the full 512gb in DOS? I'd like to avoid the opensource alternatives.
Reply 5 of 6, by Shponglefan
Brosopholes wrote on 2024-07-22, 20:45:
Just to be clear, the 8GB limit in DOS is total drive size, not partition size. The partition size limit is 2 GB. This is the maximum partition size using FAT16.
I don't know if it's possible to extend this under DOS 6.22 (since you'd no longer be using FAT16).
Since you mention reliability is a concern and don't want to use alternative DOS versions, I'd stick with the conventional limits.
Reply 6 of 6, by Ryccardo
Brosopholes wrote on 2024-07-22, 20:39:
Primary Master and Primary Slave 😀
SATA drives would typically be S1, S2, etc - but since your computer doesn't support SATA, the controller will (hopefully) have an option ROM bringing some degree of boot support for them (there are various possible approaches that may or may not integrate in the boot menu, in the latter case you'd use the "bootable addin card" option)
[photos]
With that setup, the Quantum will be drive 80 and the Seagate drive 81 (floppies start at 0 and CDs do not count), unless:
- you have a single-use boot menu (the "press F12" type) and select the Seagate, in which case that will become drive 80 and the other will most likely become 81
- the Quantum is considered non-bootable (because the first sector doesn't end in 55 AA bytes, and possibly if the operating system returns with INT19 which can commonly happen with the usual errors from Microsoft MBRs and VBRs), then the Seagate will be tried as above
- you're booting from a CD using a certain variant of the El Torito standard (there's native mode, virtual HDD drive 80 mode, various virtual FDD drive 0 modes)
I think it would be rather hard to have an usable HDD in DOS/Win16 without a MBR (which would mean using the whole disk as a partition, "superfloppy" style), on top of the mentioned capacity problems 😀 - even though ironically it could still easily be bootable, since the FAT12/16/32 VBR also ends in 55 AA and so would be accepted by the BIOS!
