Deunan wrote on 2024-07-24, 10:11:
You want a standard PC 5.25" HD drive, so that it can read and write 1.2M floppies. It will also read 360k, and even older formats (support for 160k and 320k depends on DOS, not the drive), but can't write those properly. By properly I mean it won't be readable on actual DD drive but this one will still be able to read what it has written, so you can make copies of original game floppies and create saves - no problems there.
The only reason to pick a DD drive is to make the machine period-correct, or if you want to write DD media to be readable by other DD drives. Probably not want you need.
1.2m drives write 360k diskettes just fine ...
The actual problem occurs if you write 360k disks that were previously written on a 360k drive.. the 80-track 1.2 has
thinner tracks than to 40-track 360k drives - this often leaves some of the original 360k track at the edges.
If you read the diskette back on the same (1.2M) drive - no problem, the thinner head doesn't see the "noise" at the
edges.
If however read it on an actual 360k drive, it's wider head sees the noise on top of the actual track data,
this can cause problems.
When writing 360k diskettes on 1.2m drives that you might want to read on actual 360k drives, best to do so
on a fresh (never written) or bulk-erased diskette.
Another problem can happen with non-PC formats... the 360k drive rotates at 300 RPM, while the 1.2 at
360 RPM - the PC controller "compensates" for this by using a data rate of 300kbps instead of 250kbps
used on 360k drives - this works out the same bit density for DD PC formats, but can cause problems
with SD and other formats - I've got information on my "Daves Old Computers" site about modifying
a HD drive when using ImageDisk so that it can be switches to rotate at 300 RPM, thereby making it
able to do the various formats which don't work at 360 RPM.
Dave Dunfield - https://dunfield.themindfactory.com
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
