First post, by Tempest
I have an IBM PS/2 ValuePoint 433SX that I'm attempting to use with a CF card as a hard drive. I'm using a StarTech CF adapter and an 8GB CF card (yes it's too big, but it's what I had). I know Dos 6.22 will only see up to 2GB, but when I go to create the primary DOS partition with FDISK it creates one that's 504MB and it takes up the whole card. I can't make any other partitions at all. Any idea what could be wrong? It asks if I want to use all the space and I select yes, so it should at least make a 2GB partition, but it only seems to see 504MB. DOS will install on it and it does work, but I'd like to use all space available, even if it's in 2GB chunks. Maybe DOS doesn't like this CF card? It's an 8GB Memory Partner card.
The BIOS reports the hard drive as 528MB (I think) but FDISK only sees it as 504MB. I was able to create several 2GB FAT16 partitions on it using Windows 10, but FDISK reported those as NON-DOS and I couldn't do anything but delete them (although they were there in FDISk, so that's a step in the right direction).
--- AtariProtos.com ---
For when excellence and burnished fineries need to gently visit the warmth of your tablery
Reply 1 of 17, by dormcat
Tempest wrote on 2024-07-24, 00:11:
According to this table your ValuePoint 433SX/S was announced in either April or May 1993, when the largest HDD option was 245 MB. Both Andries Brouwer and Western Digital suggested that BIOS older than August 1994 might not be able to support or recognize HDD larger than 528 MB (512 bytes/sector * 63 sectors/track * 16 heads * 1024 cylinders = 528,482,304 bytes) / 504 MiB.
IIRC partitioning FAT with a modern OS is not recognizable with FDISK of any "pure" DOS.
Reply 2 of 17, by Tempest
Hmm... I think I had a 2gb hdd in there before. I'll have to check.
Edit: well I'll be, you're right. The old drive is 528Mb as well.
Bios is L6ET53AUS. Can this be updated?
Reply 3 of 17, by jakethompson1
You need overlay software like OnTrack or EZ-Drive
Reply 4 of 17, by zwrr
This is because the BIOS limits the hard drive size to 504MB, and to solve this problem, you have two options:
1. Load OnTrack Disk Manager or EZ-Drive software.
2. Install the Mini ISA ROM Card or NIC ROM to load the XTIDE Bios.
Either way, you will be able to use a 2G hard drive partition under DOS 6.22, and if you want to exceed 2GB, you will need to use a DOS 7.10 system.
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
Reply 5 of 17, by Tempest
Ok I'll have to look into that mini isa thing. Although for a 486 500MB is pretty luxurious. Most games didn't take up that much space.
Does anyone sell those cards? Is it just plug and play or do you have to configure it?
Wasn't there a way to use a network card and an eprom?
Reply 6 of 17, by AlessandroB
I'm also interested in one of these mini ISA ROM cards to put in an IBM Ps/1 that only sees 500Mb, follow the discussion. I saw that a user on eBay sells them, only that he asks for a lot of information for the preparation of the ROM which I couldn't answer.
Reply 7 of 17, by wierd_w
Why?
This should be a no brainer with a PAL/GAL for address decoding, and some jumpers to define UMA address, and that's about it.
It shouldnt give two shits what the ROM is.
Unless the seller is specifically making XTIDE XUB cards... the XUB needs to be configured before flashing, and that DOES need dumb questions answered.
For that reason, I think a realtek nic is the more versatile solution, even if you dont want/need a nic. It supports in-card flashing.
(For reference, I am meaning a realtek rtl8019as based NE2000 compatible card. Realtek has drivers for vintage OS still up, AND the 'RPL boot rom' utility. These are 16bit ISA 10/100 cards with twisted pair abd BNC coax connectors, that have the desired/needed 64kb boot rom socket.)
https://www.realtek.com/Download/List?cate_id=597
Reply 8 of 17, by Tempest
So if I put this card in my 486 (https://texelec.com/product/lo-tech-isa-rom/) then flash the XTIDE BIOS to it then my system will use the XTIDE BIOS and I'll be able to use 2GB partitions? Is it hard to configure the BIOS for my system or are the instructions straight forward? I use an XTIDE in my 5150 and IIRC it was pretty much plug and play with no configurations required.
Actually I have a 3COM EtherLink III card (3C509B) that has an empty socket in it. Does someone sell pre-configured EPROMs? I don't have the ability to burn them myself.
Reply 9 of 17, by wierd_w
The latter issue is why I suggested the rtl8019as.
The "RPL boot rom utility" is a generic flasher for use directly in-card. Pop in an eeprom (of appropriate size abd type), point the utility at your configured xub binary, and fire when ready.
The configuration part is pretty straight forward; it just wants to know what base IO addresses to probe, and what IRQs to expect, If you want to automatically boot or loiter in the menu, etc.
Reply 10 of 17, by Tempest
I found a good video for configuring my card with a reminder of how the rom address can interfere with the onboard video which I never would have thought of. Now I just need a programmed EPROM and I think I can do this.
I'm kind of surprised no one sells pre-programmed EPROMs for this purpose. Is it against the rules to sell the XT-IDE BIOS on an EPROM or something like that? Most people don't have access to an EPROM programmer.
Reply 11 of 17, by douglar
Tempest wrote on 2024-07-25, 13:18:
If you have an XtIDE card, it can flash an EEPROM .
Reply 12 of 17, by Tempest
douglar wrote on 2024-07-25, 15:49:
I do, but it's in my 5150.
Reply 13 of 17, by wierd_w
They mean, you can take the card out, carefully remove the eeprom from its socket (and carefully place it aside), pop in the blank, reinstall the card, boot from a floppy, and then write your configured image.
THEN
Remove the burned eeprom, reinstall the original one, put it back in your 5150, and button it up.
Take the burned eeprom, pop it in your NIC/ROM Card/OTHER, put it in your PS1, and off you go.
Reply 14 of 17, by Tempest
wierd_w wrote on 2024-07-25, 17:18:
They mean, you can take the card out, carefully remove the eeprom from its socket (and carefully place it aside), pop in the bla […]
THEN
Does it take the same sized EEPROM as I need for the 3COM board?
Reply 15 of 17, by wierd_w
64kb, is usually what's used.
Reply 16 of 17, by Tempest
wierd_w wrote on 2024-07-25, 20:12:
According to this video (https://www.youtube.com/watch?app=desktop&v=ofZLDAOmZYU) the max size the 3COM card can take is 32K (go to about 9:14 to see the sizes in the config utility.
Assuming 16K or 32K work (I think the code is only 12K) what is the part number of the eeprom I'd need?
Reply 17 of 17, by waterbeesje
Eeprom (28c) or flash rom (29c) are probably supported. Then 16kB = 16*8=128kb and 2kB = 32*8=256kb so these numbers count up to:
28c128 / 28c256 / 29c128 / 29c256
You may also look at the chip that's currently installed. It's mostly written on top. Alternatively if there's a label: Loading the software for writing the ROM will also detect the installed ROM chip and return it's size, before you alter the ROM software.
Stuck at 10MHz...
