First post, by eddman
Does such a driver exist? If someone has it or has a link to it please post it here.
I'm trying to test a few things. There are differences between IBM EGA and Compaq EGA and apparently the driver of the former might not be fully compatible with it.
EDIT:
To add more context, I'm doing some bug testing on 86box. There's a bug report that when using windows 3.0 with a Compaq EGA running in 86box with the regular EGA driver, there are visual glitches. It's not clear if it's an emulation bug or driver related. I have to test with a proper Compaq driver.
P.S. I don't really have any proper knowledge of how these era compaq devices are supposed to be set up.
Reply 1 of 5, by BitWrangler
SP1198 might have it in, but it might be easier to find by exact system model
Reply 2 of 5, by eddman
BitWrangler wrote on 2024-08-01, 18:37:
It says "Compaq Deskpro 386 (May 1988)". The CPU is a 386DX. For video card you can basically select any of the listed ISA cards.
Reply 3 of 5, by VileR
The video BIOS is another possible source of differences from the IBM EGA, especially with early cards like that.
Compaq had multiple revisions of their EGA BIOS. Not sure which one 86box expects by default, but maybe a later one will fix the issues with Windows' generic EGA driver?
See https://www.pcjs.org/machines/pcx86/compaq/video/ega/ (I believe "rev E" is corrupt, but "rev G" might do it.)
Reply 4 of 5, by eddman
VileR wrote on 2024-08-02, 16:41:
... (I believe "rev E" is corrupt, but "rev G" might do it.)
Thanks. 86box emulates the hardware, so different revisions of the same bios work, AFAICT. I tested rev G but didn't help.
Where does it say E might be corrupt?
Reply 5 of 5, by VileR
eddman wrote on 2024-08-02, 18:20:
IIRC back when I tried extracting it from the .json, at least part of it came out as garbage. Maybe it's been replaced with a good one since then, but if Rev. G didn't help then E likely won't either.
