First post, by khyypio
The system specs while this issue occurred: Slot 1 Pentium 3 600 MHz E (fsb 100 MHz), RAM 384 Mb (3x128 Mb), Voodoo 3 2000 AGP
The board worked at first but the BIOS version was very old so I updated it to the latest official version. I downloaded Aflash BIOS tool V1.37 and P2B-F Beta BIOS 1014.003, put them in a floppy disk.
The attachment bios_support.JPG is no longer available
I booted to DOS and followed the instructions and the program said the update was succesful, so I exited the program and rebooted. Then there was no picture, the monitor won´t get a signal. I´ve tried the following:
- Took out CMOS battery and cleared CMOS (or at least tried)
- Unplugged everything
- Tried different jumper settings
- Tried memory sticks separately one by one
- Tried another AGP graphics card and also a PCI graphics card
- Checked the monitor and the cable
I realize the BIOS update was marked as beta but I thought that since it´s official and it´s the latest, why not. I know I should´ve gone with P2B-F BIOS 1013A, but obviously I can´t do another BIOS update before I get the video signal.
I know I´m not the first person who has faced a blank screen after BIOS update, so I´d think this can be fixed. Can anyone help me with this?
Reply 1 of 11, by zuldan
A couple of options…
1. Grab a post card analyzer
2. Grab a BIOS flasher like a Gecu TL866 II T48 Universal Programmer and flash back to the BIOS you were on
Reply 2 of 11, by butjer1010
Can't be simpler than that! Either the BIOS file, or flash tool were "wrong", so the bios chip is "faulty" now. You need to flash other bios with programmer on this eeprom like zuldan told You in last post, ant that's it! No other option, unless You have same board and You can exchange BIOSes from one board to another 😀
It's not the first time ASUS has wrong tools and bioses on their website....
Reply 3 of 11, by PARKE
khyypio wrote on 2024-08-05, 10:05:
If that update is only partially dysfunctional you can -maybe- get signal with an ISA video card.
Reply 4 of 11, by PC Hoarder Patrol
Not clear if it's only a 'no video' problem or if the system is otherwise booting properly or not.
1014.003 should be the one to use (what version were you on previously?) and as long as the vrm chip (HIP6019BCB or equivalent) and the PCBA version is OK (see https://web-archive-org.translate.goog/web/20 … &_x_tr_pto=wapp ) can't think what the issue is except a random bad flash.
I recently did my P2B-DS, but used Aflash v2.21 (attached) without issue. One difference between the versions is that v2.21 supports command line options, so maybe if the machine is properly booting you could try a 'blind' re-flash with this version...
ASUS ACPI BIOS
FLASH MEMORY WRITER V2.21
Copyright (C) 1994-2002, ASUSTeK COMPUTER INC.
USAGE: AFLASH [Options] [ROMFile]
/AUTO ROMFile Automated update BIOS without Boot Block and ESCD
/BOOT Update BIOS including Boot Block and ESCD
The attachment aflash.exe is no longer available
Reply 5 of 11, by khyypio
zuldan wrote on 2024-08-05, 10:15:
butjer1010 wrote on 2024-08-05, 10:25:
Seems like my only option is to order myself one of those flashers. So, just to be clear: I have to pull out this Award chip with the chrome sticker on it, set it on the programmer and the software installs the BIOS on it?
The attachment IMG_20240805_174324.jpg is no longer available
PARKE wrote on 2024-08-05, 11:58:
No such luxury as ISA video card in my possession 😁
PC Hoarder Patrol wrote on 2024-08-05, 14:27:
Not clear if it's only a 'no video' problem or if the system is otherwise booting properly or not. […]
ASUS ACPI BIOS
I don´t think it´s booting properly, as it´s not giving any beeps as it normally does. But if I power it on without any RAM sticks, it gives the warning sound so it has some life in it. Too many twists and turns to try a blind re-flash, it simply won´t amount to anything 😂 I think the previous BIOS was 1008...?
Reply 6 of 11, by Karbist
Does it attempt to read the floppy disk when you turn it on?
Reply 7 of 11, by butjer1010
Karbist wrote on 2024-08-05, 16:47:
If it beeps without ram, maybe its not fully "wasted" 😀 If the BIOS doesn't function at all, there would be no beeps without ram sticks....
If You don't have any isa graphics cards, the best thing is programmer. It is very easy to operate with software for "flashing" new bioses. You need to remove chrome sticker to see and set the chip version in programmer, erase eprom, load bios bin file, and program it.
Reply 8 of 11, by khyypio
Alright, thanks for the help everyone! I hope this thread is useful for anyone who´s struggling with this same board. Here´s a little update:
The only viable option was to purchase one those programmers (XGecu T48) to flash the chip.
The attachment IMG20240824131106.jpg is no longer available
I flashed the latest BIOS release to the chip, didn´t work. From there I continued flashing with older versions until finally 1012a.bin brought it back to life. I don´t know if the flash program just required a .bin file. After that I tried flashing from floppy with Aflash and the bios file, version 1013 was the latest BIOS that worked for this board so I´m going forward with this version. Now I just have to figure out what I´m going to with this programmer that I spent 100€ for and don´t need anymore...
The attachment biosver.JPG is no longer available
However, my issues with this damn board aren´t over just yet. At first it didn´t detect any of the drives, optical nor storage. I initially had 80-wire IDE cables for all of them because many says that they are the best choice because even if the mobo can´t fully utilize them, it just uses them as 40-wire cables. Not so, I swapped them with 40-wire ones and now it sees the drives. Well, at least it sees the SD adapter but it can´t see either a 64 or 16Gb SD card, just says it´s 32 Mb.
It seems that many, or at least some of you are familiar with these boards, have you faced this same issue? Why doesn´t it recognize the SD card, is there something in the BIOS setup that I need to configure?
Reply 10 of 11, by khyypio
Well, I don´t know what I did but all of sudden it sees the SD card correctly. Go figure... Anyway, thanks for the help everybody!
Reply 11 of 11, by soggi
Maybe you didn't chose the right 1014.003 file as there are a lot different ones for each P2B derivative. Below I attached the right one from ASUS' FTP. I always recommend these latest ASUS betas as they are very stable and have many things fixed. To flash these (older) BIOSes I always recommend UniFlash 1.40 or higher which can be found on my website f.e. (-> https://soggi.org/motherboards/bios-update-fl … h-utilities.htm).
I would give it a second try.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
