Unregistered wrote:
The initial poster apparently fixed that problem in about a half hour, but, how?
I got rid of the black screen simply using the launcher..... then running the game with the "Run with VDMS" option that has music icon
Fisu wrote:
I Patched Laura Bow 2 CD with new audblast.drv. Now speech works, but it always cuts after a secound of playback or so with every line. Is there anything to be done here? I Also tried the gosierra patch, but it didn't do anything.
I am using Vdmsound 2.04 with launcher patch and Windows XP SP1.
EDIT: looks like I fixed it. Solution was to set sbversion to Sbpro.
Try adding this line on the DOS Environment tab, under the AUTOEXEC.BAT area.... :
SET BLASTER=A220 I5 D1 H5 P330
But leave the IRQ option under Sound Blaster at 7
