First post, by Malik
- l33t
If anyone from here uploaded the floppy disk images of Night Hunter game (published by Ubisoft, 1988) to REMOVED please PM me as I need to know if there is any problem with the PC speaker sounds (some sounds are not playing correctly -picking up keys, and sucking the blood sounds) both 5.25 and 3.5 floppy versions. Using 86Box to test the games. (IBM PC XT 4.77MHz and 286 10MHz configurations.)
Thank you.
Edit: I found out that problem is with 86Box and not the floppy images themselves - When I copied the directory from the hard disk image and run the game under Dosbox, the sounds play fine. I will contact 86Box author with this information.
Thank you to whomever uploaded the images to REMOVED 1 to 1 copy of floppy disks and good images are very important in today's world. We might lose all these floppies forever if not preserved. And FYI, I still do have a boxed copy of the Night Hunter game, but not sure of the quality of the floppies inside.
