First post, by AGP4LIfe?
I picked up a pretty Rare PCI version of the R6, DDR SGRAM version from ebay. Unfortunately it is missing two capacitors? (See Pictures) and doesn't boot.
The attachment PXL_20240804_013706034~2.jpg is no longer available
The attachment PXL_20240804_013741451~2.jpg is no longer available
I am looking for tips or Idea's on where to get the missing parts! My instant take could be buying a agp donor card off of ebay, but that is an expensive proposition.
Is there anywhere to get these little buggers cheap?? or new old stock ect. ect. I'm open to thoughts and ideas!.
Thanks for your time!
Who decides what truth is, and what is their objective? Today’s falseness can reappear as tomorrow’s truth.
Reply 1 of 11, by Deunan
These look to be some power filtering/bypass caps. I don't think just the two of them missing would stop the card from working completly, though it's not entirely impossible. Just put some 100nF there with at least 16V rating and that's it. Hard to say from photos like these but probably 0603 size caps.
Reply 2 of 11, by MikeSG
I think they're 100nf/0.1uf caps as Deunan said.. the card should still work.
If you're not a soldering guy you could leave it, or search on ebay. 0805 in/2012 mm is a good middle size. 16v - 50v. Ceramic capacitor.
Reply 3 of 11, by dm-
oh, i have the same card but for MAC,
could you please dump bios image from you card?
ps.
card should work w/o capacitors 99%
Reply 4 of 11, by AGP4LIfe?
Thank you all for the advice! Much appreciated 👍, yea unfortunately it doesn't boot pretty surprising because physically it's good shape.. but there is a possibility of something else being wrong too. I'll look around for some cheap ceramics!
The attachment PXL_20240809_141345044.jpg is no longer available
Reply 5 of 11, by Deunan
AGP4LIfe? wrote on 2024-08-09, 14:10:
Yup, like it being a Mac card with non-x86 ROM. Reflashing it without desoldering the chip might be tricky, not to mention there might be some configuration jumpers that need to be changed as well.
Reply 6 of 11, by Trashbytes
Deunan wrote on 2024-08-09, 15:09:
Should be able to just flash it to the PC ROM, IIRC the MAC rom simply has some extra boot code on it the MAC needs and there were no hardware changes.
Will need one of them flash adapters that clips onto the ROM, can find them on Evil Bay pretty easy.
Reply 7 of 11, by AGP4LIfe?
Good point I never even considered it might be mac card.
Reply 8 of 11, by AGP4LIfe?
Trashbytes wrote on 2024-08-09, 15:24:
Roger I'll see what I can find, as I have zero mac's in the house.
Reply 9 of 11, by dm-
as i said before, i have same card, it is for PowerMAC
you can flash it using regular atiflash. it is not a problem, just boot from another vga card.
i flashed mine with ATI DDR 32mb image. it is working, but DVI is not available since original ATI DDR has no DVI.
looking for image with DVI enabled.
Reply 10 of 11, by AGP4LIfe?
dm- wrote on 2024-08-11, 09:20:
as i said before, i have same card, it is for PowerMAC […]
Did you need a special flash adapter? or did you just put it in a pci slot with a secondary video card to boot and flash it?
Reply 11 of 11, by dm-
nothing special,
just one more vga card.
do not use ati card to not mess things in atiflash.
use atiflash utility for dos and image from radeon.ru:
https://radeon.ru/bios/ddr.zip
