Touche in XP?
First post, by Unregistered
I get an "Vesa screen diver not found"
Any help?
Reply 1 of 4, by Snake785
If you have the launchpad, you can select "Enable Basic VESA Support" in the properties of the exe file and it should work.
Reply 3 of 4, by Snover
Well, when you choose "Enable basic VESA emulation" does it go full-screen? If not, then you probably haven't checked the box. 😜
Yes, it’s my fault.
Reply 4 of 4, by Nicht Sehr Gut
All the VESA switch does is allow your program to start in full-screen mode instead of a window.
It sounds like there's some kind of VESA compatibility issue. Not knowing the specifics, I would recommend creating a batch file for use with NOLFB.COM.
NOLFB.COM
TOUCHE.EXE
Also, remember that it can only be run from C:\TOUCHE
If that doesn't work, you have precious few options...
Dual-boot or emulation via VPC or similar tool.
