Syndicate DOS / Win98 Problem
First post, by JamieReleases
Hello,
I hope everyone is doing well. I'll start by listing my specs and that the game is Syndicate. I didn't see any threads for not using Dosbox.
Win98/DOS
Intel Pentium III 500mhz (512k cache 100mhz fsb)
IBM 300 GL 6563V1G Motherboard
256mb Hynix PC133 SDram
3DFX Voodoo 3 2000 16mb AGP Card
Creative Labs Soundblaster Live! 5.1 SB0100 PCI
NEC IBM Badged 3 1/2" Floppy Drive
I've installed it, but it just doesn't load up. Crashes on start-up. Does anyone have any recommendations on what to do to get it running or come across this themselves? I've not tried disabling sound yet, so I'll give that a go to see if it's that. I don't want to run it all under an emulation in Dosbox, I'd rather learn how to fix these things, but if it's easier I suppose. Not seeing too much information on this one though. The manual says about a turbo mode on video cards, but I can't see an option in the bios or elsewhere to turn this off with the Voodoo 3. I'm slowly remembering everything, but it's been great playing these old classics again.
Reply 1 of 24, by feda
You're right, it's easier to just run it in Dosbox.
But I'd guess the cause is memory-related, as many games are fussy about it.
I would see how much memory you get in pure DOS with the mem command.
Also post your autoexec.bat and config.sys contents.
Reply 2 of 24, by ludicrous_peridot
Not sure which version you are running, but I have tried the one from gog with both machines in my sig with their "native" sound drivers and both main game and American Revolt worked. I remeber crashes when I started it from the launcher on the newer machine with PCI soundcard, but if I went to the game directly bypassing launcher and intro (separate executables) then I remember I could play fine. Sorry if this does not help much, but if you have questions about my configuration, disk layout and such I'll be happy to tell. Good luck.
GA-G41M-Combo G41/ICH7 - Core 2 Quad Q9550 - DDR3 1033 - Radeon RX570 - CMI-8738 - X3MB - CM-300 - Saitek ST-30
Beetle/M/i815+ICH2 - Celeron 566Mhz - Opti 924 - YMF740 - MT-100
https://archive.org/details/peridot-26
Reply 3 of 24, by jmarsh
I remember there was at least one version of Syndicate which shipped with a version of DOS/4GW that always crashed when 32MB or more of XMS was available. You could just replace the extender .exe with one from a different game.
Reply 4 of 24, by wbahnassi
Interesting. I have the same crashes on pretty much every machine I tried it on. In my case, it crashes near the end of the intro cinematic. However, that was the disk version. The CD version works fine. I'll do some experiments with less memory and with an upgraded DOS4GW and report here.
Turbo XT 12MHz, EGA, MFM HDD
Intel 386 DX-33, Speedstar 24X, SB 1.5, FDDx3
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
IBM BlueLightning 100MHz, CL5428, SB16, 4x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, RTX2060
Reply 5 of 24, by jmarsh
If the game actually starts it's not likely to be a problem with DOS/4GW.
Reply 6 of 24, by badmojo
I've had problems with Syndicate on fast machines - it's sound driver related I suspect because the problem goes away when I don't configure sound blaster.
Slowing the machine down to ~66Mhz 486 speeds fixes it for me.
Reply 7 of 24, by JamieReleases
Thanks for all the replies, guys. It loads up to the part where you pick normal Syndicate or American Revolt, and then just goes black when I select. I can't even get to the intro cinematic. This is the CD version. I'll copy my autoexec.bat and config.sys contents over to this machine shortly.
Reply 8 of 24, by JamieReleases
I found a different execute file on the CD, which seemed to load into the original game instead of going to the splash screen. The intro plays, and the game works, but only the music. There's no sound. I can't see any sort of installer with it where I can pick sound options... Does anyone else see a sound setting file within their CD?
Reply 9 of 24, by Sombrero
JamieReleases wrote on 2024-08-26, 18:12:
In the original floppy version the sound is set during installation and the address/IRQ stuff can only be changed by editing SYND.BAT once the game has been installed, so I suggest taking a look at your installation folder and see are there any .bat files there.
As far as I know the original floppy version only supports Sound Blaster 2.0 and the later Syndicate Plus CD edition added SB16 support. I remember reading about someone upgrading their SB2.0 to SB16 which immediately caused the CD edition of Syndicate to not work anymore, there might be something odd about how the CD version handles sound.
Reply 10 of 24, by JamieReleases
Sombrero wrote on 2024-08-26, 19:37:
It looks like the CD install just creates a folder to place saves with an INF file for the audio, but editing it everything looks correct - IRQ, DMA etc...
Reply 11 of 24, by JamieReleases
If anyone knows why FMV cutscenes are so macroblock too on multiple games, I don't remember this back in the day, but maybe I didn't realise at the time. I'm using a Dell E771A CRT.
Reply 12 of 24, by feda
Macroblock?
Reply 13 of 24, by vstrakh
feda wrote on 2024-08-29, 16:54:
Macroblock?
Macroblocks are the square areas (8x8,etc) that video codec operates on.
The bitrate was kept low to allow realtime decoding on the hardware of the era, so when there's lots of motion in the scene - there are not enough bits to express all the changes in a frame, the video codec has to prioritize large changes first (means the base color/gradient of all blocks in affected areas), and then the details would be gradually refined in a calm scenes as more data is pushed through.
Reply 14 of 24, by wbahnassi
Well, IMO Sierra's FMV compression was probably one of the worst during its time (e.g. see Phantasmagoria and Urban Runner). Their later title increased the HW requirements and thus improved the quality (Phantas 2, Gabriel Knight 2). If you are running on a 17" monitor or larger, I recommend avoiding the full-screen video option. It will make things much worse with its simplistic upscaling and black lines.
Syndicate's intro FMV is not blocky at all though. It sacrifices frame rate instead of image quality.
But yes, those blocky artifacts were noticeable to me since their days, but the entire technology was super exciting to see emerging for the first time (memories of Windows 95's Weezer video 😅)
Reply 15 of 24, by jmarsh
I don't recall exactly what codec Bullfrog (Syndicate, Theme Hospital, Theme Park, etc.) used for their videos, it was probably Smacker, but I definitely remember it would just blindly skip decoding frames if the CPU was too slow leading to very obvious blocks left on screen from older frames.
Reply 16 of 24, by JamieReleases
wbahnassi wrote on 2024-08-31, 05:28:
Well, IMO Sierra's FMV compression was probably one of the worst during its time (e.g. see Phantasmagoria and Urban Runner). Their later title increased the HW requirements and thus improved the quality (Phantas 2, Gabriel Knight 2). I recommend avoiding the full-screen video option if you are running on a 17" monitor or larger. It will make things much worse with its simplistic upscaling and black lines.
Yeah, some games look great and you don't get a lot of compression on the FMV scenes, but some have been awful. Alone in the Dark New Nightmare is pretty unplayable even in-game, all the dark scenes look messy like they were done in paint. I don't know if there's Codex that can help or some drivers. I've had many of my big box PC Games for years, just waiting for the time to finally go back and play them natively. Rogue Squadron looks amazing on this PC, and I've been able to play lost games like Dark Omen and War of the Worlds again. When I move out in the future I'll probably build a dedicated 486 machine for DOS games, and maybe a smaller monitor would be better for that to help the FMV scenes. Finding monitors seems hard these days though. Alone in the Dark and older dos games are quite troublesome due to the sound I suspect. I'm branching off onto all sorts of convos here though, but a lot to learn and talk about sorry haha.
Reply 17 of 24, by ludicrous_peridot
For me FMV sequences in Syndicate don't look blocky, but they also don't always looks FMV-ish, at times resembling "spriteesh" digitally painted animations of the "before prerendered" times, so I wouldn't know if technology was not really sprite animation layered on top of pre-rendered backdrop frames. Again, I have GoG version, so CD may be different.
If one looks for a really outworldly video codec, by the way, look no further then Cryo's Dune CD-ROM. They stuffed in clips from Lynch's movie in a rather peculiar way. I am using these clips as reference for scaler testing these days. 😀
Reply 18 of 24, by butjer1010
ludicrous_peridot wrote on 2024-08-25, 09:14:
It worked for me also 😀
I started the game from syndicat folder, main.exe file and everything worked normally....
Reply 19 of 24, by wbahnassi
The proper way to launch the game is synd.bat , not via any of the direct executables (original version, I don't have the GoG version).
