Internal debugger
First post, by MrPrise
Hello!
The debugger seems to jumps through a few instuctions when I use F11 key. I expect if I press F11 it advances to the next instruction. Am I doing something wrong or this is a feature?
Thx.
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
could you give an example ? (code sequence)
it should be one instruction.
Water flows down the stream
Reply 2 of 3, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Don't use dynamic core.
1+1=10
Reply 3 of 3, by MrPrise
I switched to full core and it works normally.
Thanks for the quick answer!
