Possible reasons why two drives would be selected at once:
1) The floppy cable is direct, missing the "twist" between the DRIVE A:
connector and the DRIVE B: connector. - This twist moves the signals for
drive A: select and motor-on to the drive B: positions on the furthest
connector. This means that drive A: has to be jumpered as B: - and in
fact is most likely why IBM did this - they only had to sell/stock one
floppy drive (which was jumpered as B: and would work as drive A: at the
cable end connector (past the twist), and drive B: at the inner connector
(no twist). Unfortunately (IIRC) these signals don't line up exactly to
a standard cable/FDC and you can't just use a straight cable with drive A:
jumpered as A:
2) The floppy drives are jumpered incorrectly. As noted above the drives
must BOTH be jumpered as drive B: - the actual logical position A: or B:
is determined by the placement on the cable.
3) Floppy cable plugged in backward!
All the pins on one side are ground, and the drive select inputs activate
the drive at 0V - so plugging in the cable backward will ground all the
selects and activate all the drives.
This seems unlikely since your system reports one drive - but I've encountered
BIOSs which always report a configured A: drive is present!
Easiest way to tell if this is the problem is that drives will come on as
soon as you power the system (even before any self-tests), and will not go
off - they also won't seek during detection.
If both drives come ON together a bit after power, and both go OFF
together (and possibly seek together during their detection), then it is a
good sign that the problem is related to the select configuration and not
a reversed cable.
4) This won't be the problem if you have had two drives working on this system
before, but I have encountered mainboards which only implement one floppy
drive select, and a few of those activate that one drive on either select
(that way the customer doesn't have to know how to jumper drives or have
to change out the drive cable.
Dave ::: https://dunfield.themindfactory.com ::: "Daves Old Computers"->Personal
