First post, by Queen K Juul
I am trying to play the game Hi-Octane over my LAN between a MS-DOS 6.22 486 and a 98SE Pentium 3. On the 486, the game is running great, and I've installed the 1.2 patch in addition to Netware client, and I find the "Enable Network" option in the settings and activate it.
On Windows 98, though, the game doesn't run. The intro video plays, then I get a blue screen requesting "insert diskette for Drive B:" - problem is, this machine has no drive B:, and it requests Drive B: no matter where I install the game - C:, D:, or from the CDROM (F:) - every time it asks for a diskette in B:, and then the "disk read error abort, retry, fail" until I ctrl-alt-delete and kill the game.
I know some games save the expected CD drive to a file, but I couldn't find anything to that effect for this game.
Does anyone know what's going on?
Unfortunately I don't believe there exist DOS/Netware drivers for the RTL8169 which is in my P3 rig, so I don't think I'll have luck getting the LAN running in pure DOS mode, but I can't get the game running at all in 98 right now. I've looked into Dali/IPXbox, if I can get a packet driver, would Dali let me run the Netware NetBIOS TSR, and then could play the game over the network? Or do I need the full Netware client stack? I can't find a manual for the game and I don't understand how NetBIOS is supposed to work.
Reply 1 of 2, by chinny22
Found this which has a dos ODI driver?
https://www.realtek.com/Download/List?cate_id … 583&menu_id=297
I've never had win9x IPX and dos IPX been able to see each other. I suspect it's due to MS been a cutdown version, I don't think it allowed you to connect to a Novell server either?
Maybe installing the Netware client for Windows would give you a "proper IPX protocol"
https://www.zx.net.nz/netware/client/9x.shtml
I know I got the game running with no-cd, just not sure if I needed to patch anything. I think the hioctane folder from the CD needed to go into c:\ ....something did but can't check as all my retro rigs are packed away.
Reply 2 of 2, by Queen K Juul
chinny22 wrote on 2024-09-12, 05:57:
Found this which has a dos ODI driver? https://www.realtek.com/Download/List?cate_id … 583&menu_id=297 […]
ah i swore I'd looked on the realtek site. Of course I just went to all the effort to install an RTL8139 in place of my 8169 🤣 oh well. I had tried the NDIS drivers previously and had bad luck with them, but I hadn't used Netware before.
I was hoping to use Windows 98 for the SBLive software wavetable support but I guess I could live without it if it means working LAN play. I'm gonna try the same stack on both machines now and see what happens. Unfortunately it seems my SBLive just abruptly died though so I'm pretty upset about that.
