First post, by Zordaks
I tried to make my own build of dosbox (for windows) and add this capability by myself however i have been most unsuccesful in compiling the source code. I have tried this with a few compilers with no success. I have managed to get rid of all the compilation errors except the last one. The compiler does not seem to be able to find a "main" function. I tried compiling this with a windows console application project with no luck.
i can create my own main function (if this is needed) but i dont know what in the source code should be called on by this function. can someone help me with this?
Thanks, Tom
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
please don't use caps.
and have sdl properly installed.
the main error is caused by a bad sdl install.
Water flows down the stream
Reply 3 of 5, by Guest
I did not... i will now hopefully it will work out.
sorry about the caps.
thanks
Reply 4 of 5, by HunterZ
(Fixed the caps in the subject)
Reply 5 of 5, by Zordaks
I tried compiling with the instruction on the page. I am using the DLL's from the DOSBOX dsitribution but i am having no luck with setting the path variable to where i put the DLLs.
How do i do that? I think i must be missing somthing. I tried the normal linux way but it seems to be ignoring me.
thanks again
