First post, by pool7
I've been searching but couldn't find any topic on this; apologies if there is and I missed it.
While investigating sound cards, the following came to my mind. It's not a new thought, but it's been a while since I've had it and never asked nor researched about it.
Most of the times, drivers are bundled with additional software (ie. Geforce Experience, ; either in disc or as download. In many cases it is just bloat that can be skipped; however I've had one or two cases where part of the software was required for proper functioning of the device, and I have a feeling sometimes it is a good thing to install some of it.
Greatest examples are drivers (again, disc or download) from Nvidia and Creative.
Which software bundled with drivers do you consider:
-a must have (hardware will work partially or not work at all without it); can't think of any example at the moment
-recommended (improves the experience); example: some fine tuning app to adjust settings that cannot otherwise be adjusted
-avoid at all costs (bloated app, redundant, etc); example: DVD player software
Ideally, please reply based on experience, including:
device model
OS
driver/software version
small description for your suggestion
Reply 1 of 1, by chinny22
I've always been a minimalist so only install what's strictly required.
Creative SB Live! and newer cards are a good example and one where I break this rule typically installing in addition to the drivers
AudioHQ, EAX Console, Creative Surround Mixer
I do this just in case I need it but remove all from startup, and don't think I ever really use it.
additional crap included in Graphic card drivers get removed as none of my games require it.
Things like the freefall sensor included in laptops you can install via the unknown device within device manager rather then installing the whole software package.
Infact apart from Chipset, graphics and sound I prefer installing via device manager rather than running the installer.
