First post, by renejr902
I have serious problem. asus P2B-VE motherboard ( hp oem ) always display conflict in win98 with agp videocard. With any agp card. geforce 4 mx 440, geforce 4 mx 440se, geforce 4 mx 420, geforce 2 mx 400.
Your display adapter conflicts with another device in your computer. To correct this problem click OK to view the properties for this device
This device cannot find any free Input/Output Range (I/O) resources to use (Code 12).
If you want to use this device you must disable another device that is using the resource this device needs. To do this, click HARDWARE TROUBLESHOOTER and follow the instructions in the wizard.
This board is 3.3v only for agp so no tnt2 card work and no radeon and no ati rage 128 work. they dont even boot up. i heard the long beep 2 or 3 fast beep.
The board has a integrated ati rage pro THAT I THINK CAN BE DISABLED. no jumper anywhere. no option in bios. i have the last bios 1.14. Maybe i could use a modded bios if you know of one that can work.
The pc build is slot 1 Pentium III 450mhz.
128mb sd ram 100mhz
40gb hdd
i didnt installed any sound card yet.
I tried several things to get it working no luck yet.
disable floppy, serial port... everything.
i even try using a pci tnt2 in it and win98 installed the tnt2 and the ati rage pro at the same. no conflict but d3d hardware not available for any card.
when i installed a geforce agp videocard, only that card show in device manager with a yellow !
I think this board is somewhat incompatible with all agp videocard. i dont get it.
some people with similar era motherboard seems to have this problem and find no solution.
Before you ask, i installed intel chipset driver when i saw this problem, but itnchanged nothing.
I forgot to say, when a agp geforce vudeocard is installed in the motherboard, sometime, not very often, the pc boot with the long beep and 2 fast beep. i have to disconnect the power and try again. it do this with all my agp geforce card. but it wont do it often.
integrated ati rage pro works properly when alone
Thanks a lot for help.
Reply 1 of 13, by renejr902
i just saw a jumper for disabled integrated video card. my bad. i will try it. i missed it first time i check the board.
Reply 2 of 13, by renejr902
all is working now. thanks anyway
Reply 3 of 13, by Thermalwrong
renejr902 wrote on 2024-09-25, 13:42:
Cool 😀 I have one of these boards in storage and haven't done much to test it, so knowing that the onboard video conflicts with an AGP card confirms that it is definitely using the AGP bus and you've confirmed it can be disabled.
Great that you've got it working properly, I think it's a pretty nice board
BTW I think that a TNT2 should work on the board now that the onboard one is disabled. AGP 2x boards aren't that limited normally.
Reply 4 of 13, by dionb
It shouldn't be necessary to disable onboard video to get an AGP card to work. PCI and AGP VGA can coexist happily, in fact normally you can select in BIOS which should be primary. Of course, no reason to leave the onboard VGA on if you're not using it, but I suspect this was more a software issue than anything else.
As for TNT2 - 3.3V should be no problem, it can work at either AGP 1.0 (3.3V) or AGP 2.0 (1.5V), same as the GeForce2MX you have working there. So if it doesn't work, it's not the voltage.
Reply 5 of 13, by renejr902
dionb wrote on 2024-09-25, 16:18:
i just lost 5 hours. all graphics are corrupted in.direct 3d games with any geforce card or tnt2. all radeon froze o whileninstalling driver 🙁 Please help me
i dont find any jumper to change mhz speed of agp
Reply 6 of 13, by renejr902
check this. all 4 geforce card do this.
with 45.23 driver or nfroce 81.98
Tested with these agp card: geforce 4 420, geforce 4 440mx se, geforce 4 440 mx, geforce fx5500.
all theses cards work in my other system
Moto Racer 1
Reply 7 of 13, by renejr902
tried another power supply. same thing
Reply 8 of 13, by renejr902
its unbelieveble 🙁
it does the same glitch in moto racer with a PCI tnt2
i changed the cpu and ram memory. same thing
Reply 9 of 13, by renejr902
the integrated gpu work correctly in moto racer.
if the problem is speed of pci and agp, i dont know what to do. thanks for help
Reply 10 of 13, by renejr902
nobody have a idea 🙁
Thanks a lot
Reply 11 of 13, by renejr902
finally i sold it to a vogons member.
Reply 12 of 13, by Linoleum
renejr902 wrote on 2024-09-28, 14:51:
Happy to have relieved you! I am now cursed with this board... 😉
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 13 of 13, by renejr902
LoL Thanks again
