First post, by Unregistered
I don't know if this has been discussed before, but since I saw it as an issue on the compatibility area, I'll go ahead and post it anyway.....
I was messing around with the launcher and it's settings and found a way to get rid of that nerve breaking audio loop on VGA Sierra games.....
Using the launcher, create the VDM shortcut and use the following custom configuration :
On Sound Blaster use IRQ 5
But on the DOS Environment type in the following on the AUTOEXEC.BAT area
SET BLASTER=A220 I7 D1 H5 T6
You might need to download the latest AUDBLAST.DRV that were released.....
This did the trick on Conquest of the Longbow & Dagger Of Amon Ra..... Haven't tried it on others.....
I'll be messing around with KQ5 next... let's see if there's a miracle on the making
