I see, thanks for the info! ^^
Yeah, there's sometimes a bit of an compatibility issue between MS-DOS 5/6 and XT era firmware or hardware.
For example, old real-time clock drivers written for MS-DOS 2 or 3 do lock up modern MS-DOS or do other weird things.
Generally speaking, MS-DOS 6.22 is very 16-Bit friendly, though.
I've been running it flawlessly on a couple of 286 and 8088 systems..
If you need more storage, you can try Compaq DOS 3.31 (has larger FAT16 support) for example or some of the other cool OSes.
PC-MOS/386 or Wendin DOS can multitask DOS applications, for example.
They do need lots of conventional memory by comparison, though.
There's a chart over here: Conventional Memory consumption of various DOSes
IBM's DOS is also an alternative.
Beginning with PC-DOS 3.30, IBM's DOS was nolonger 1:1 the same to MS-DOS (they used to be built from same sources).
PC-DOS 3.30 was a bit more advanced than MS-DOS 3.30, also.
Back then it freshly supported PS/2 and clone computers. And 1,44 MB floppies.
