IBM PS/2 Model 60
First post, by soupapes
Hi,
Bouth this PS/2 Model 60 and need some help from the experts to bring it to life, since I dont know much about it.
Tried to turn it on and I get errors 162 and 163.
I think 163 os related with CMOS battery which I already ordered one.
What could be 162?
From what I read online these machines require a reference disk to setup. I found a specific one for this model with version 1.08 which I recorded the image in a floppy disk using WinImg.
When turning on the machine with the disk inserted, the floppy drive tries to read it but nothing happens and I end up in the Post screen with the two errors mentioned above. Should I assume the floppy drive is bad? Or do I need to take any special procedure to go to the setup of the reference disk?
Another question: I do see what it seems to be an expansion card with alot of memory sticks, but at post only finds 1mb. Is this expected?
- IBM Aptiva 2176/P200MMX overdrive/Voodoo 4mb
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 1 of 22, by luckybob
oh boy, are you in for a treat. IBM is a wonderful platform, but it is not for the uninitiated.
#1 - Here is the massive list of IBM PS/2 error codes: http://ps-2.kev009.com/pcpartnerinfo/ctstips/49fe.htm
#2 - The floppy drives used to be relatively stable and worked good. However in recent years they have really fallen off because of bad caps. If I made a pie chart of IBM floppy drive failures, 5% of failures would be dirt/grime, 90% for caps, and last 5% would just be other dead chips.
#3 - yes, you likely only have 1mb of ram onboard. You will need to use the reference disk to setup the add-on board.
There are 20 things to go wrong here, but the most notable ones are...
1. Clean the drive first. It can just be old-sticky grease. This is a universal issue with all drives.
2. it is VERY easy to write a reference disk and windows will do it wrong. There is a flag that gets written to the boot sector of the floppy that tells the system it is a reference disk. Windows likes to "correct" this "error" if you aren't careful. I personally use win-image, and I will eject the disk as soon as possible after writing it. If Windows so much as looks at it,
3. IBM floppy disks are NOT directly compatible with the standard 3.5" drives - adapters exist and are cheap: https://www.youtube.com/watch?v=SkvL_H_hVKc&p … HBzLzIgZmxvcHB5
4. the caps are likely hoop-a-jooped.
You will need a 2nd floppy with the correct ADF file for each add-on card. These can be standard format floppy disks. you can just copy the ADF files to the floppy. You can put as many ADF files as you want on this 2nd disk. https://www.ardent-tool.com/adapters/ADF.html That said, it looks like you have the IBM memory expansion with 2MB ram. The ADF should be on the base model 60 floppy so, you shouldnt need a 2nd floppy. https://www.ardent-tool.com/memory/IBM_Expansion.html
You should just bookmark www.ardent-tool.com 99% of all PS/2 info is there.
Reply 2 of 22, by luckybob
OH! Be careful with the "foam" inside the case. It is made of the same stuff as this guy: https://www.youtube.com/watch?v=XHIgSNw4V0U
Reply 3 of 22, by eisapc
Welcome to the world of PS/2 microcomputing.
There is also a newsgroup comp.sys.ibm.ps2.hardware, as well as a facebook group.
Some more info like lots of adf files can be found at
www.mcamafia.de
Feel free to contact me via PM, I own a PS/2 model 60 myself and many other IBM PS/2.
Reply 4 of 22, by soupapes
What a awesome feedback.
Thank you for sharing all the information!
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 5 of 22, by Intel486dx33
It’s a Beauty.
I would Start with cleaning the case and internal components.
Look for broken or loose components.
Definitely clean the heads on the floppy drive with some Isopropyl alcohol.
Write down the bios version
Clean and reseat all the cable connections and cards.
Dust brush, Vacuum, and Isopropyl Alcohol is your friend.
Reply 6 of 22, by soupapes
It seems I made a mistake and bought the wrong battery on Amazon.
The battery taken is the one in the photo and does have a reference 2CR17335SE-V
Im trying to find a compatible battery in size and voltage.
Do you know if this model is compatible:
Panasonic Photo Lithium Battery CRP2 (Nickel-Oxyhydroxide (NiOx), 6 V, 1400 mAh, 34 mm, 17 mm, 45 mm)?
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 7 of 22, by luckybob
https://www.ardent-tool.com/misc/batteries.html
according to the gospel, yes.
i personally have the 223 cells on hand
Reply 8 of 22, by soupapes
Today finally I took some time to clean most of the dust with air gun.
Also took off the Mitsubishi floppy drive to inspect and clean the heads with alcool, but still no luck.
The drive does spin, the light comes on, but cannot boot from the floppy disk.
Should I try to replace those 5 caps?
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 9 of 22, by soupapes
Finally some progress... Replacing the caps fixed the floppy drive. I'm so happy to see the blue screen of the reference disk.
After setup the system time, i'm now only having an error 164. At post only gets 2MB memory.
Im trying to configure the HD which I believe to be a Seagate 44Mb with part number 6373507, but I have no idea which values to submit.
I do see a Slot 8 with 3 parameters to be defined. Is that the right place? Not sure which values to submit.
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 10 of 22, by luckybob
well, it looks like you have 1mb of ram on the motherboard, and an additional 2mb on the card, that seems right.
if you run auto config, do you have any options?
As for the slot-8 thing. The point of the IBM "bios" is to auto-magic the assignment of memory locations, IRQ, DMA, ETC. You should leave most if not all settings on default. that said, I like to disable serial and parallel ports unless you plan to use them. This give the bios more resources to work with when you add things like scsi, sound, network, etc
The auto-config should read the hard drive and configure itself. if its not doing that, the drive may be cactus, and that would 100% cause an error like 164.
Reply 11 of 22, by soupapes
luckybob wrote on 2024-10-25, 19:12:
well, it looks like you have 1mb of ram on the motherboard, and an additional 2mb on the card, that seems right. […]
The auto config always fails to detect the HD, so I believe it might be dead.
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 12 of 22, by luckybob
it might also need a recap like the floppy drive. also double check all the cables and what not. I'm going to assume that this is the only ESDI drive you have?
MY way to replace the ESDI hard drive is to get a MCA scsi card and a SCSI hard drive.
There also exists a new MCA card that allows for CF cards. I dont personally own one, but thats probably the best option for someone who doesnt have a huge stockpile of IBM hardware.
Reply 13 of 22, by soupapes
luckybob wrote on 2024-10-25, 19:51:
I will try to check this massive block of HD and see if I can find some caps to be replaced.
I saw the MCA CF adapter, but is very expensive with shipping and import tax from US to Portugal, problably close to 150 usd.
I think my best option is try to find a used MCASCSI card...
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 14 of 22, by luckybob
soupapes wrote on 2024-10-25, 19:58:
If you think that's expensive, have a look at the prices of original sound cards. the last one I saw was several years ago and it went for like $1500 US. EVERYTHING with IBM and PS/2 is going to cost extra. Thankfully the 'new' SoundBlaster clones have really enabled these machines to be viable gaming setups.
https://virtuallyfun.com/2023/09/17/installin … ainful-lessons/
You are going to want to AVOID non-IBM scsi cards, at least as boot devices. They are perfectly fine for additional external devices like CD drives. If you do decide to risk it, stick with the Adaptec 1640 MCA card. I have used that one personally and I can attest it works fine in 90% of cases. the Scsi cable is a bit hard to find, but its literally just an 50-pin edge connector. with some patience you can find them still around. Without the benefit of a cache of hardware, I'm going to reiterate the CF MCA card is likely going to give you the best experience here, unless you get lucky on auction sites.
IBM can get into some really strange corners when it comes to non-ibm parts in their machines. its usually fine, but the edge cases will drive you up the wall.
Reply 15 of 22, by soupapes
luckybob wrote on 2024-10-25, 20:15:
If you think that's expensive, have a look at the prices of original sound cards. the last one I saw was several years ago and […]
The floppy drive started randomly failing, so I end up buying the CF MCA card and the floppy adapter from ZZXIO. Great products.
I got a 256mb CF card and installed MS DOS 5.02
The next issue I have is a POST 164 error which seems to be related with the expansion memory card or the ram sticks, bue in the BIOS detects a total of 3mb (1+2).
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 16 of 22, by soupapes
I was able to fix the post 164 memory error.
The memory card came with 8 sticks with mixed brands:
-4 sticks 'OKI MSC2304-15YS9A'
- 4 sticks 'Mitsubishi MH25609BJ-12'
By removing the 4 Mitsubishi sticks the error was gone and I get a total of 2mb (1mb from board and 1mb from memory card).
In a google search it seems both brands have similar specs but the OKI are faster with 150 ns, while the Mitsubishi are 120 ns.
It seems having mixed brands does not work or maybe the Mitsubishi are not compatible with the memory card.
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 17 of 22, by weedeewee
soupapes wrote on 2024-12-15, 09:10:
FYI, 150ns is slower, 120ns is faster.
Do not ask Why !
Reply 18 of 22, by soupapes
weedeewee wrote on 2024-12-15, 10:58:
Good to know, thank you for clarifying that.
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
Reply 19 of 22, by soupapes
3d printed a front plate for the floppy drive.
- IBM PS/2 model 60
- IBM PS/2 55 SX
- IBM PS/1 2133
- IBM PC 330 - P90
- 486 DX2 66
