Robbbert wrote on 2024-10-07, 05:42:Thanks for the info. I downloaded and installed RetroZilla 2.2 as you suggested on my 98 machine. It looks like Netscape. […]
It was able to visit any site that I chose without getting rejected because of security issues.
https vogons worked, but the same formatting issues as I had before, including no logon fields.
I then tried to visit Youtube, access was allowed, but of course it froze having run out of memory. No surprise there.
As for IE6, I think this was at the time when it couldn't be uninstalled because MS insisted it was part of the OS. I mean, I could stop using it, but the underlying tech is stuck there afaik.
It is hardly possible to add the features to let www.vogons.org function correctly. But you can always ask for support, f.e. roytam1 himself at MSFN in his builds thread (-> My Browser Builds (Part 5)).
Jo22 wrote on 2024-10-07, 13:14:
@Soggi Hi! From what I remember, Firefox 3.0 was the first release to introduce Gecko 1.9, which did overhaul the rendering.
So quite a few modern websites from after 2010 may require Firefox 3. Gecko 1.9 also passed Acid2 test.
This is correct - I just said above that the latest Firefox 2 version isn't "mostly 20 years" old, but ~15 years. No matter which version you use, you won't have success, I guess - it's mostly about modern JS. Adding some polyfill add-on like palefill for Pale Moon (and forks) could help, but I don't know how difficult it would be and if it's possible at all.
Speaking of my experience with Win9x and Internet.. Well, I do remember this one person who had an Windows 95 PC and a modem..
Since then, I'm very careful when it comes to Windows 9x on the Internetz. Story here.
You're talking about it yourself in the linked post... 😉
That was a connection by modem (dial-up), so you had a direct connection and the computer was directly visible to others over the Internet with its IP. I also remember the time of the early 2000s... We had a LAN party, WinXP was relatively new and the PCs of my friends got infected with Sasser because we all used dial-up connections (no matter if 56k/ISDN/DSL) back then - my PC didn't got infected because I still used Win98SE which doesn't have run services with open ports and stuff. So running Win98 behind a router is save, as save as your router and all the other devices are and as save as your behavior is (opening every e-mail attachment, downloading everything from everywhere, allowing all JS on websites, etc. !?).
@all Tip: If you're leaving your Windows 9x systems online, you maybe want make sure that the Windows Scripting Host (WSH) is being deactivated.
https://en.wikipedia.org/wiki/Windows_Script_ … curity_concerns
Why? If you are using scripts which you don't trust and which are potentially infectious, you've got other security problems and already did something wrong. Then deactivating WSH doesn't help much.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
