Write text files
First post, by ram9
My application is launched via DosBox and should write text files, but as a result all written files have a size of 0 bytes. How to solve this problem?
Reply 1 of 10, by konc
There is not enough information to provide any kind of help.
Reply 2 of 10, by ram9
DOS application needs to write text files to a specific directory. Files are created, but they are all empty
Reply 3 of 10, by vstrakh
Many things can go wrong on your side, it's not possible to tell without more info, or better - the source of minimum example reproducing the problem.
Reply 4 of 10, by gerry
konc wrote on 2024-10-09, 12:27:
vstrakh wrote on 2024-10-09, 16:44:
at least you tried ...
strange how on many forums there are these very short requests (amusingly this example shortened even further when prompted for *more* detail.. 😀 )
I've seen it so many times and am never sure what the requesters are expecting, it's like you could answer "press Ctrl-x and then capital P three times and it will work" and get "ok" in response, just very odd !
Reply 5 of 10, by Errius
Remember that all text files must terminate in one or more 0x1A characters and be multiples of 128 bytes in size.
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 6 of 10, by vstrakh
Errius wrote on 2024-10-14, 12:48:
That's some weird spec.
It could have been a case for a certain environment, idk, like some editor based on screens (e.g. old Forth implementations, or some Basic), but this is not something true for DOS or a text files in general. Even if some software api's might react on 0x1A as end of file marker when opening the file for reading in a text mode - at best missing the 0x1A would mess up the reading loop, but not the ability to write the files, as stated in the question.
Reply 7 of 10, by Errius
I was joking. That's how things were done in CP/M and DOS 1.0 days.
ETA: some examples of such files
Reply 8 of 10, by vstrakh
Found the 128 byte requirement relevant to CP/M, the directory entry for the file specified the length of the file in 128-byte records (the echo of 128-byte sectors on 8" disks?), and the CP/M version 2.2 and below didn't store the number of bytes in the last 128-byte record. It makes perfect sense to pad the last 128-byte record with EOF symbol then 😀
The DOS 1.0 FCB structure is built with similar patterns in mind, tracking access to the file in blocks of 128-bytes by default, but it seems it's more of an abstraction there. The block size may be changed, and the FCB has the 4-byte field specifying the length of the file in bytes, so the alignment should be irrelevant? I guess the FCB and also the Pascal's way of handing 'untyped' files was designed specifically to support this 'normal' (at the time) flow - 128-byte records by default, but can be changed when you 'reset()' the file.
Reply 9 of 10, by Grzyb
In the 80s, it was common for text editors for DOS to add the 0x1A byte at the end of file - I recall eg. Norton Editor behaving like that.
You can also create a text file by "copy con filename", then finish the input with Ctrl-Z - it should also add the 0x1A byte.
Yes, DOS was created with CP/M compatibility in mind...
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 10 of 10, by gerry
so that wasn't a wasted thread in the end 😀 hope the op came back and learnt something!
