First post, by pjturpeau
Hello everyone,
I've picked-up this Aztech I38-MMSN850 card but I failed to identify the exact model (see attached picture).
It is similar to this one Sound Galaxy Nova 16 Extra II but with few differences:
1. no IDESEL and JMPBO jumper setting on the bottom-left corner
2. no EC9, EC11, EC12, EC13 condo in the middle of the card
3. no JMPCFG jumper setting on top of the AZT816 chip
4. no JX1 jumper setting near the upper-right corner
And I'm just asking myself what would be the right DOS/Win9x drivers for this model.
Thank you.
Reply 1 of 8, by Grzyb
Seems to be Multimedia Pro 16 ABI/ABO, but:
"The card was also sold to third parties who rebranded it. One example of this is the Toptek Golden Sound Pro 16 ES/MCD."
https://dosdays.co.uk/topics/Manufacturers/aztech.php
Drivers:
https://dosdays.co.uk/topics/Manufacturers/az … ads.php#MMPro16
In 2003, I voted in favour of joining the European Union. However, due to recent developments - especially the restrictions on cash usage - I'm hereby withdrawing my support. DOWN WITH THE EU!
Reply 2 of 8, by soggi
The alphanumeric identifier "I38-MMSN850" is just the FCC ID for this card.
On https://retronn.de/imports/hwgal/hw_aztech_cs4231a_2.html the picture of the alleged Sound Galaxy Nova 16 Extra II has the FCC ID "I38-MMSN850", but if you have a look at the drivers on the (mirrored) Aztech FTP (ftp://retronn.de/mirrors/ftp.aztech.com.sg/sg/NOV16EII/, see index.txt), it should have the FCC ID "I38-MMSN846" - I don't think it makes some remarkable difference, just wanted to note that.
BTW I own a very similar card which obviously seems to be an OEM card for Packard Bell.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 3 of 8, by dionb
Tbh, Aztech had such a mess of commercial names for their cards, both retail and OEM, that the FCC ID is the only decent unique identifier. MMSN850 it is then 😉
As for drivers: it doesn't need any for DOS. This card has the AZT2316 controller, which is a non-PnP chip. So all you need to do is to run the config tool to set resources. Windows does need drivers (can't recall if there are AZT2316 drivers in Win98SE by default; AZT2320 definitely is), and Grzyb's links contain both.
Reply 4 of 8, by pjturpeau
Thank you for your help.
Sadly, for now none of those drivers are working with this card.
I get "Sound card is not found!" or "Sound card is not detected!" depending on the driver version.
I found very strange to have all hw jumper settings removed from the card.
I found one photo from a Poland auction site which have all the jumpers and the capacitors, but the chip is an AZT2316 while mine is an AZT2316-S
https://a.allegroimg.com/s1024/0c54b5/8214aa5 … 76354101922086d
Reply 5 of 8, by soggi
Hm, I had a look at the index.txt in the FTP's top directory...there's no FCC ID "I38-MMSN850"mentioned, unfortunately.
ftp://retronn.de/mirrors/ftp.aztech.com.sg/sg/index.txt wrote:
SOUND GALAXY AUDIO PRODUCT UDPATES ================================== […]
1ST GENERATION SOUND CARDS
BXII Sound Galaxy BXII Card Updates - FCC-ID:I38-MMSNBX2
NXII Sound Galaxy NXII Card Updates - FCC-ID:I38-MMSD801
NXPRO Sound Galaxy NXPro Card Updates - FCC-ID:I38-MMSD802
NXPRO16 Sound Galaxy NXPro16 Card Updates - FCC-ID:I38-MMSN803
BASIC16 Sound Galaxy Basic16/Pro16 Card Updates - FCC-ID:I39-MMSN810
PRO16 Sound Galaxy Pro16L/Extra Card Updates - FCC-ID:I38-MMSN808, 812
BASAUD Sound Galaxy Basic Audio 16 Card Updates - FCC-ID:I38-MMSN813
2ND GENERATION SOUND CARDS (USING AZT-1605 CHIPSET)
NOVA16 Sound Galaxy Nova 16 Card Updates - FCC-ID:I38-MMSN815
NOV16E Sound Galaxy Nova 16 Extra Card Updates - FCC-ID:I38-MMSN811
P16II Sound Galaxy Pro16II Card Updates - FCC-ID:I38-MMSN822
ORION16 Sound Galaxy Orion16 Card Updates - FCC-ID:I38-MMSN816
3RD GENERATION SOUND CARDS (USING AZT-2316/A/R CHIPSET)
WRIDER Sound Galaxy Waverider 32+ Card Updates - FCC-ID:I38-MMSN826
NOV16EII Sound Galaxy Nova 16 Extra II-3D Card Updates - FCC-ID:I38-MMSN846
P16II Sound Galaxy Pro16II Card Updates - FCC-ID:I38-MMSN845
WRP323D Sound Galaxy Waverider Pro 32-3D Card Updates - FCC-ID:I38-MMSN852
4TH GENERATION SOUND CARDS (USING AZT-2320 CHIPSET) - PLUG-N-PLAY MODELS
P16III Sound Galaxy Pro16III-3D PnP Card Updates - FCC-ID:I38-MMSN853
WR32PNP Sound Galaxy Waverider Pro 32-3D (I) PnP Card Updates - FCC-ID:I38-MMSN853
WRIDER96 Aztech Waverider Platinum-3D PnP Card Updates - FCC-ID:I38-MMSN853
SC16 Aztech SC16-3D and SC16-3D(W) Card Updates - FCC-ID:I38-SN97125
SC128 Aztech PCI 128-3D Card Updates - FCC-ID:I38-MMSN97126
OTHERS
FMRADIO Sound Galaxy FM Radio Card Updates
MISC Miscellaneous
Turtlebeach Aztech Turtlebeach Montego I Sound Card Win9x driver
I also found another thread about drivers for Aztech sound cards, have a look at Help to Identify Aztech ISA Sound Card.
kind regards
soggi
Reply 6 of 8, by pjturpeau
Thank you for the link to the thread, but again no success at all.
I think it is definitely a broken item.
Reply 7 of 8, by SSTV2
This card is not very promising considering that the previous owner removed several components from it.
With "JMPCFG" and "JMPB0" jumpers absent, It's now set to read resource config data from the EPROM chip, which may be corrupt. A simple test can be done to determine the operation of the card, just short pins 1-2 of "JMPB0" and pins 2-3 of "JMPCFG" jumpers with a solder blob, and enter this line anywhere in the autoexec.bat - "SET BLASTER=A220 I5 D1 H5". This way card will use default SB resources in DOS environment and you won't even need a specific card driver for the sound to work in games and other programs, such as MOD trackers.
It would also be a good idea to add at least EC12 - 47uF and EC4 - 100uF before testing. Also make sure that there are no shorting pins on the main chip, because some appear to be.
Reply 8 of 8, by pjturpeau
Thank you for the details. I'm not sure I'm able to do that by myself. I may probably throw the baby to a friend...
