First post, by boggit
The other day, I purchased a Commodore 1084s-P2 monitor, hoping to be able to use it with my C64 as well as with my CGA-based IBM 5160/XT (original IBM CGA card, original 5160 motherboard).
Unfortunately, the screen I got seems to be one of the later, cost-reduced variants that lacks the option for digital RGB, only offering the analogue RGB that the Amiga would use:
* I managed to get excellent picture on the screen when connecting my Commodore 64 via S-Video. I'm using a converter that goes from the port on the C64 and diverges into three RCA connectors. Sound was definitely decent as well, though only coming out of the left speaker (using a converter that connects to the C64 port and then splits up into three RCA connectors, with only one for (mono)sound).
* However, when hooking up the CGA-equipped XT system to the monitor via composite cable -> PAL/NTSC converter -> composite cable (to the bottom left of the four RCA jacks in the rightmost part of the picture above), I could only get either somewhat shabby monochrome/greyscale picture or extremely bad sorta-color mode rather than the fully decent composite CGA color mode I get when going composite on my LCD (through a hdmi converter).
See below:
Mode CO80 in DOS, Color wheel on front of screen turned to color:
Mode CO80 in DOS, Color wheel on front of screen turned to no color:
Mode BW80 in DOS, Color wheel on front of screen turned to color:
Mode BW80 in DOS, Color wheel on front of screen turned to no color:
Questions:
* What can I do get good artifact CGA colors on this screen?
* Am I correct in thinking that I should adjust Capacitator C1, as per this information?
* If so, and this might be a stupid question, but can I adjust C1 while the system is running, or would that be potentially dangerous?
