In my never ending quest of creating a most universal machine now I face this weird issue, it could be due to the use of a ssd coupled with an adapter but the same thing happens if I use a cf card.
Programs like doom and quake works fine but if I try to use stuff like dosidle or HWINF623 they hang with a message like this: "MS-DOS version not compatible with the version of Windows. Insert the reboot disk for this version of Windows.
I get this message (just in my local language): https://misterfpga.org/download/file.php?id=3 … 9c04db95a1ff649
I tried to mess with bios options (use a slower udma mode, disable the multiblock transfer), nothing worked except that when I boot the system without emm386 (or jemmex) everything works fine, I thought it could be a issue of too much ram (despite I patched windows98 which worked fine last time). but I was unable to find a way to limit the memory. I also tried to switch to a more vanilla version (himem.sys + emm386) but nothing changed. If I use only xmgr.sys those programs works fine.
Any help of how I can solve the issue or any troubleshooting?
Hm. Strange. That reads like MS-DOS 6.22 was being used for starting Windows 9x..
On other hand, Windows 95/98 DOS (DOS 7.x) and its associated utilities did identify itself as "Windows" sometimes.
If you can, try loading SETVER in config.sys. Maybe it helps.
New entries for SETVER can also be made manually.
Edit: Windows 3.x and 9.x need real himem.sys in order to work.
Windows 9x needs himem.sys from DOS 7.x, which supports XMS v3.
Using an older himem.sys or a replacement (FreeDOS, QEMM) is not going to work.
Jo22wrote on 2024-10-19, 20:59:Hm. Strange. That reads like MS-DOS 6.22 was being used for starting Windows 9x..
On other hand, Windows 95/98 DOS (DOS 7.x) and […] Show full quote
Sorry, I didn't mention but I tried setver already.
All the files I'm using are coming from a windows 98se, so there is no risk of mixed stuff. Also according to dosidle it's designed to work without any memory manager but it states it should work fine even with one enabled.
I also tried to try strip down config.sys and autoexec.bat leaving only xmgr and emm386 (no other drivers) but I get the same error, with jemmex I tried the most conservative settings, same issue.
At the same time programs like doom and quake works fine even with emm386 loaded, it's probably because they use their own dos extender.
As mentioned I also tried the himem.sys from windows directory, it changes nothing.
Hm. Not sure. I'm not familiar with DOS 7 (anymore).
I just vaguely remember that MS-DOS 7.x loads himem.sys automatically, -for Windows 9x-, unless a setting in msdos.sys is changed (it's a text file in DOS 7).
If that setting is changed, himem.sys will nolonger being automatically loaded and the user can load himem.sys manually in config.sys.
Or use a different XMS manager, if needed.
Edit: Correction. It might have been DOS=NOAUTO in config.sys (HIGH, UMB can be left added).
If set, it will not load HIMEM.SYS, IFSHLP.SYS, DBLBUFF.SYS, ASPI2DRV.SYS, SETVER.EXE automatically.
I'm sorry but I think you are probably confusing with windows me (dos 8 ) which automatically loads those files (which are integrated), either way I changed the switch on my config.sys from auto to noauto, it just avoid to load the file IFSHLP.
Auto:
1Moduli utilizzanti memoria al di sotto di 1 MB: 2 3 Nome Totale Convenzionale Memoria superiore 4 -------- ---------------- ---------------- ---------------- 5 SYSTEM 35.664 (35K) 9.920 (10K) 25.744 (25K) 6 XMGR 2.320 (2K) 560 (1K) 1.760 (2K) 7 EMM386 4.176 (4K) 4.176 (4K) 0 (0K) 8 COMMAND 10.064 (10K) 0 (0K) 10.064 (10K) 9 CTMOUSE 3.104 (3K) 0 (0K) 3.104 (3K) 10 SHSUCDX 6.176 (6K) 0 (0K) 6.176 (6K) 11 DISPLAY 8.304 (8K) 0 (0K) 8.304 (8K) 12 XDVD2 160 (0K) 0 (0K) 160 (0K) 13 IFSHLP 2.864 (3K) 0 (0K) 2.864 (3K) 14 KEYB 6.944 (7K) 0 (0K) 6.944 (7K) 15 DOSKEY 9.840 (10K) 0 (0K) 9.840 (10K) 16 Disp. 735.968 (719K) 640.496 (625K) 95.472 (93K) 17 18Riepilogo della memoria: 19 20 Tipo di memoria Totale Usata Disponibile 21 ---------------- ----------- ----------- ----------- 22 Convenzionale 655.360 14.864 640.496 23 Superiore 170.432 74.960 95.472 24 Riservata 0 0 0 25 Estesa (XMS) 2.150.393.4 2.410.048 2.147.983.3 26 ---------------- ----------- ----------- ----------- 27 Memoria totale 2.151.219.2 2.499.872 2.148.719.3 28 29 Tot. inf. a 1 MB 825.792 89.824 735.968 30 31 Dim. massima di un programma eseguibile 640.480 (625K) 32 Dim. massima di un blocco libero di memoria superiore 87.792 (86K) 33 MS-DOS Š residente nell'area di memoria alta.
Noauto:
1Moduli utilizzanti memoria al di sotto di 1 MB: 2 3 Nome Totale Convenzionale Memoria superiore 4 -------- ---------------- ---------------- ---------------- 5 SYSTEM 35.648 (35K) 10.544 (10K) 25.104 (25K) 6 XMGR 2.320 (2K) 560 (1K) 1.760 (2K) 7 EMM386 4.176 (4K) 4.176 (4K) 0 (0K) 8 COMMAND 10.064 (10K) 0 (0K) 10.064 (10K) 9 CTMOUSE 3.104 (3K) 0 (0K) 3.104 (3K) 10 SHSUCDX 6.176 (6K) 0 (0K) 6.176 (6K) 11 DISPLAY 8.304 (8K) 0 (0K) 8.304 (8K) 12 XDVD2 160 (0K) 0 (0K) 160 (0K) 13 KEYB 6.944 (7K) 0 (0K) 6.944 (7K) 14 DOSKEY 9.840 (10K) 0 (0K) 9.840 (10K) 15 Disp. 738.832 (722K) 639.872 (625K) 98.960 (97K) 16 17Riepilogo della memoria: 18 19 Tipo di memoria Totale Usata Disponibile 20 ---------------- ----------- ----------- ----------- 21 Convenzionale 655.360 15.488 639.872 22 Superiore 170.416 71.456 98.960 23 Riservata 0 0 0 24 Estesa (XMS) 2.150.393.4 2.410.064 2.147.983.3 25 ---------------- ----------- ----------- ----------- 26 Memoria totale 2.151.219.2 2.497.008 2.148.722.1 27 28 Tot. inf. a 1 MB 825.776 86.944 738.832 29 30 Dim. massima di un programma eseguibile 639.856 (625K) 31 Dim. massima di un blocco libero di memoria superiore 91.280 (89K) 32 MS-DOS Š residente nell'area di memoria alta.
As matter of fact it changes nothing, I have the very same crash. I did another try though, I loaded the system with shift+f5, I did mem and checked what there was, just command and system stuff, then I enabled dosidle which worked fine then I loaded jemmex (with load -v) then I tried to give the mem command then I got an error (it was what I was hoping for):
exception 06 occured at CS:EIP9C97:00000386, *another 2 lines of errors*.
Hm. Maybe you're right. I do admit I know very little about MS-DOS 7.x, I'm more of an MS-DOS 6.22 person. 😅
Sorry, I have no clue at the moment.
My Windows 98SE laptop currently has Helix memory manager loaded and XMGR is not loaded.
XMGR seems to be a Windows 9x specfic program?
I read that it can be used to run Windows from plain DOS, so that himem.sys isn't required.
Edit: Silly me! I've confused it with XMSMMGR.EXE. 😅
Jo22wrote on 2024-10-19, 22:49:Hm. Maybe you're right. I do admit I know very little about MS-DOS 7.x, I'm more of an MS-DOS 6.22 person. 😅 […] Show full quote
No xmgr is a substitute of himem (http://optimizr.dyndns.org/dos/drivers.html) and it's not the problem since if I just load xmgr the app starts fine, the problem is the emm (jemmex works as substitute of himem+emm386) if I load it those apps crash.
Helix memory manager are you using it with msdos 6.22 I suppose, right?
Um, yes, that, as well.
I'm using it for VMs running MS-DOS 6.22, sometimes in combination with Qemm 9.
The Compaq laptop here runs normal MS-DOS 7.1 and Windows 98SE, though. Together with the Helix bundle (Helix Multimedia Cloaking), which is Win95 compatible.
Windows 3.1 is also installed in a separate dirrctory. Partition is FAT16, because the HDD is small.
So I have been able to somewhat alleviate the issue.
You were right that windows 98 automatically loads some drivers (when it's selected to boot the "gui"), after I changed from AUTO to NOAUTO, I had to add some lines on config.sys:
Since the issues I had were when booting on dos, those are just for future reference.
I modified the boot files a bit and now I am able to make dosidle works even with an emm (doesn't matter if emm386 or jemmex). It's not clear actually what changed the situation, when I run HWINF623 everything still crashes in a bad way.
What makes instead crash the system every time is the microsoft mouse driver (9.01), it really goes nuts on a hardware level, the speaker squeaks 3 times, the leds on the keyboard begins to lite (all 3) and then it says it found no mouse, after that dos apparently boots fine but then every program crashes (in a different way from the other crash, like if there was any memory segmentation fault).
Tomorrow I will try if I will be able to troubleshoot the issue even more. In the meanwhile, I was able to make run sbemu on dos but I can't find the right drivers for windows 98 (and xp?). The codec is the classic ac'97 the chip which provides it it's the sis 7012.
I've found some drivers (one called a12112d_SIS_7012_audio__realtek_rl5383_ which includes driver for both xp and 98 but the card doesn't get detected).
Some details:
Vendor: 1039h
Device: 7012h
Subsystem ID: 030013F6h
Obviously on ecs website they do not provide any audio driver for this motherboard: https://www.ecs.com.tw/he/Product/Motherboard … s/specification
Just to avoid any problem. I began from scratch. Installed a fresh copy of windows 98 after a format, I kept the config.sys and autoexec.bat as most vanilla as possible:
