First post, by havli
- Oldbie
Hello everyone 😀
I recently bought this nice board. It is i440BX chipset in microATX form - and the most interesting part, it has onboard Riva TNT with 16MB SDRAM. I intend to built retro PC for windows98 gaming and some late DOS games too. The configuration is:
Pentium III 500 (Katmai)
1x 128 MB RAM
Onboard Riva TNT
Voodoo2 SLI
ESS 1869
20GB IDE HDD
DVD drive
Everything runs well enough after initial testing. There is one small catch. On a warm reboot (either restart command from w98 or ctrl+alt+del) the POST takes very long time. It hangs at the basic screen where CPU model is shown, storage devices, etc. It just sits there for 1-2 minutes and nothing is happening. After this time runs out the board just beeps and proceeds with booting the OS and everything runs nicely.
It behaves like this on most warm reboots but not all of them, maybe 80% are slow. When I turn the machine of and on again, then it always POSTs normally (like 5 seconds). When I press the reset button, it also POSTs normally.
I suspect the problem might be BIOS version. Seems to be the very first release for this board. Do you have similar experience with Intel made boards of this era? Any idea if new BIOS could fix it? I can flash later bios of course but it is a bit risky business because the flash chip is soldered on this board and it isn't the usual PLCC package but rather something else, much harder to solder in case anything goes wrong. I also tried disabling all non-essential devices like COM ports, LPT, Floppy controller... but this makes no difference. Also removing the PCI and ISA devices makes no difference.
And another question - what are the HDD size limits on these Intel boards? The bios is from January 1999. I know boards from this era usually have the limit at 32GB and when patched, can go up to 127 GB or so. But here when I connected 120GB SSD (through IDE-SATA adapter) the BIOS detected 64GB size... which is new to me 😀 The limit most likely isn't 32GB because 40GB HDD can use the whole capacity.
Thanks 😀
