First post, by aLinux
aLinux
Offline
- Newbie
Hello
i installed windows 3.11 on dosbox-x and i got mouse/sound working perfect but cant seem to get video drivers to work.
i downloaded so many drivers but i keep ending in black screen after install or asking for "s3 flat model trio64v driver disk".
i added my dosbox.conf here if someone can please help me with some working drivers cause i cant get it to work 🙁 please !
[sdl]
autolock=false
mouse_emulation=integration
[dosbox]
title=Windows 3.1
memsize=128
[video]
vmemsize=8
vesa modelist width limit=0
vesa modelist height limit=0
[dos]
ver=7.1
hard drive data rate limit=0
floppy drive data rate limit=0
[cpu]
cputype=pentium_mmx
core=auto
integration device=true
[midi]
# mpu401: Type of MPU-401 to emulate.
# Possible values: intelligent, uart, none.
# mididevice: Device that will receive the MIDI data from MPU-401.
# Possible values: default, win32, alsa, oss, coreaudio, coremidi, none.
# midiconfig: Special configuration options for the device driver. This is usually the id of the device you want to use.
# See the README/Manual for more details.
mpu401=intelligent
mididevice=default
midiconfig=
[sblaster]
sbtype=sb16
sbbase=220
irq=5
dma=1
hdma=5
sbmixer=true
oplmode=auto
oplemu=default
oplrate=44100
[fdc, primary]
int13fakev86io=true
[ide, primary]
int13fakeio=true
int13fakev86io=true
[ide, secondary]
int13fakeio=true
int13fakev86io=true
cd-rom insertion delay=4000
[render]
scaler=none
[autoexec]
echo off
mount c .
c:
cd windows
win
