First post, by Mamba
Hello,
I have a strange problem.
After a fresh install of XP SP2 on a Super7 machine, I am unable to install DX9.
Basically it starts to install but at the very end of the process it fails and revert back.
I am referring to the redistributable package.
https://www.3dfxzone.it/programs/?objid=655
The motherboard refuses to work in 3D (not even 3dmark 2000) with nvidia cards, either mx or fx52000, so it is not a matter of power usage.
But works with a Radeon 9250 just fine (2300 3DMark 2001SE and Egosoft X2 loaded properly - a slideshow actually but works).
I installed the SP3 and .NET packages but no differencies.
Do not know if it is related to this issue.
any clues?
Reply 1 of 19, by eddman
Why are you installing that ancient version. Install the latest one.
Reply 2 of 19, by leileilol
eddman wrote on 2024-10-24, 09:24:
They don't make DX10/11/12 for XP...
Reply 3 of 19, by myne
Update xp.
Windowsupdaterestored.com will make it easier
Sp3 is most of it, but there might be other weird dependencies
I built:
Reply 4 of 19, by Mamba
Really…?
Reply 7 of 19, by dormcat
eddman wrote on 2024-10-24, 09:49:
leileilol wrote on 2024-10-24, 09:33:
Mamba wrote on 2024-10-24, 09:36:
Really…?
Feb 2005, ancient, really. There's more than one DX9 redist.
Wow, I didn't know the very last DirectX End-User Runtime for WinXP was released in June 2010 and re-uploaded by Microsoft in 2021 until bumping into this thread.
Reply 8 of 19, by Nemo1985
Is this 2010 release of directx compatible with windows 98? Or just from XP onwards, the page states you need at least xp.
Supported Operating Systems
Windows Server 2008, Windows XP Service Pack 3, Windows Server 2003 Service Pack 1, Windows Server 2003 Service Pack 2, Windows 7, Windows XP Service Pack 2, Windows Vista
The version of dx9c I use on windows 98 is from 2005, is the latest one for that OS?
Reply 9 of 19, by Mamba
Yes I am using XP sp3 as stated in my post.
I will reinstall everything.
Probably I messed up something.
Reply 10 of 19, by myne
Did you at least try what I said?
I built:
Reply 11 of 19, by Mamba
myne wrote on 2024-10-24, 11:29:
Yes, of course.
No changes.
I think I will use from the beginning the automatic update this time
Reply 12 of 19, by soggi
Nemo1985 wrote on 2024-10-24, 11:06:
Apart from (security) fixes it is officially as follows (Windows version -> DirectX version)...
  • Windows 95 -> DirectX 8.0a
  • Windows 98 (SE)/ME -> DirectX 9.0c (Dec 2006)
  • Windows 2000 -> DirectX 9.0c (Feb 2010)
  • Windows XP / 2003 -> DirectX 9.0c (Jun 2010)
If someone is in need of these versions, they are available for download from my website on the tools page (-> https://soggi.org/misc/tools.htm). All the other localizations than DE and EN of the DirectX 8.0a redistributable package will be added with the next update (~someday), the DirectX 9.0c packages are multilanguage.
kind regards
soggi
Vintage BIOSes, firmware, drivers, tools, manuals and (3dfx) game patches -> soggi's BIOS & Firmware Page
soggi.org on Twitter - inactive at the moment
Reply 13 of 19, by Nemo1985
soggi wrote on 2024-10-25, 03:21:
Apart from (security) fixes it is officially as follows (Windows version -> DirectX version)... […]
If someone is in need of these versions, they are available for download from website on the tools page (-> https://soggi.org/misc/tools.htm). All the other localizations than DE and EN of the DirectX 8.0a redistributable package will be added with the next update (~someday), the DirectX 9.0c packages are multilanguage.
kind regards
soggi
Thank you for the precious clarification Soggi.
Reply 14 of 19, by soggi
Nemo1985 wrote on 2024-10-25, 03:24:
As always, you're welcome, Nemo1985! 😀
kind regards
soggi
Reply 15 of 19, by Jo22
Mamba wrote on 2024-10-24, 09:55:
Really…?
It would be the same.
Well there *are* DirectX 10 files for Windows XP, as well as projects similar to KernelEx (that Win 9x project). And they work, more or less. They're unofficial, though.
Edit: Whether they work on a K6 is another topic, though, since Vista files are being involved.
Reply 16 of 19, by Mamba
kind regards
soggi
Thank you so much!
I reinstalled win98se and took advantage of your site as well.
Everything is ok.
Reply 17 of 19, by eddman
After installing Dec 2006, it's possible to install up to Nov 2007 on 98/98 SE, and up to Feb 2010 on ME.
Windows XP ... -> DirectX 9.0c (Jun 2010)
Jun 2010 requires at least XP SP2. SP1 and base XP are limited to Feb 2010.
Reply 18 of 19, by DosFreak
Here's what I have locally:
*I'm not currently tracking modifications to DirectX .dlls or bypassing installers
98FE
*Requires Pentium
Directx_dec2006_redist.exe
d3d9x_xx.zip (from D3dX9_24 to 41.dll)
98SE-ME
*Requires Pentium
DX90C.exe (last file in package is 9-7-2007
2000
*Requires Pentium
Official - directx_feb2010_redist
Unofficial
dxJun2010w2kb.exe (BWC)
XP
directx_Jun2010_redist
Make your games work offline
Reply 19 of 19, by soggi
Mamba wrote on 2024-10-25, 17:34:
Thank you so much!
Everything is ok.
You're welcome! 😀
eddman wrote on 2024-10-25, 17:48:
OK, this is new to me, never heard about it before. Unfortunately I didn't bother with it for over ten years, but I remember that I tested a lot back then. Does it really add new/updated files and why Feb 2010 doesn't work on Win98SE if it works on ME? The latter is kinda suspicious to me.
Yes, this is possible, WinXP always means fully updated XP on my website. Personally I never used WinXP longer below SP2, it was unusable to me before SP2.
kind regards
soggi
