First post, by Linoleum
I've been working on my P2 setup for few weeks...It uses a HP Condor 1 (P2B-VE) motherboard. The moment I was mostly done with the project (software only), it wouldn't post.
The first time could smell burning followed by a long beep, pause, and then 3 or 4 beeps. I tried again and fans are spinning without any other beeps.
I tried:
- removing all card and all drives
- moving the ram, replacing the ram
- reseating the cpu, replacing the cpu
- reseating the psu, replacing the psu
- visual inspection: nothing
- nose inspection: nothing
Now, with the POST diagnostic card I get these two codes (at the end):
3A: Auto Size Cache
28: Auto Size DRAM
Any ideas are more than welcomed!
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 1 of 46, by Trashbytes
Check caps and SMDs around the VRM and then around the Ram slots, sounds and smells like something has let the angry pixies lose. Hopefully it didn't send voltage the wrong way and take something important with it.
Reply 2 of 46, by Linoleum
Trashbytes wrote on 2024-11-01, 01:15:
All caps are rated at 1000uf 6.3v. I checked capacitance for all them caps... There are 10 caps in a row beside VRM where 9 of them seem to be within their rated range (900uf) while 1 is in the range of 4700uf. However, i am measuring them with a multimeter on pcb; which I don't believe is very reliable... Even if this cap is not bulged, shouldn't it be closer to the 9 if they are (and seem) to be in the same circuit?
PS2 30/286, SBP
Reply 3 of 46, by akimmet
The burning smell was likely a shorted tantalum. That is where I would concentrate on first.
Reply 4 of 46, by Linoleum
akimmet wrote on 2024-11-01, 02:55:
I assume it's these two orange-yellow caps (CT-25 & CT-26) you are referring to... Any specific way I can test them before proceeding?
PS2 30/286, SBP
Reply 5 of 46, by Unknown_K
I had a marginal power supply blow up southbridge chips on a P2 board and a P4 board before.
Reply 6 of 46, by momaka
Since you are getting POST codes as high as the board checking cache and DRAM, that should (in theory) rule out anything to be majorly wrong with any of the hardware. Unfortunately, there's still a lot that can be wrong.
For example, it could be that a MOSFET or voltage regulator has failed, letting in higher or lower voltage than it's supposed to. In such case, the board could still pass POST in regards to the voltage rails checks.
It could also be a random part failure causing the issue - anything from an IC going shorted or "wonky" to a resistor going open-circuit. I actually (and coincidentally) also had an ASUS board fail on me recently - a CUSL2. It worked fine the first two times I had it running (configuring CMOS.) Then I powered off to connect some HDDs and... nada, would power up for a second and turn off. After a few tries, it powered On... only to not POST at all. I put my finger on various components (ICs) on the board and noticed the clockgen IC was burning hot... and that's where I've left it off. There's nothing in the vicinity of the clockgen IC that appears to be bad, so it looks like the clockgen IC itself has just failed. Why? - I have no clue. I suppose we will know when I replace it (need to make an order for it still.) But old parts can fail out of the blue.
In my case, I'm not sure if the PSU contributed to the issue, too. It's an old PSU, but I've recapped it completely. But it's an old CWT design I'm a bit skeptical about, and I've had a few issues with various PCs with that PSU in it. Coincidence maybe? In any case, it's more of a reminder that I will never ever test any unknown PC/motherboard without a 100% known-good PSU anymore - that means choosing one of my Delta, LiteOn, Chicony/HiPro, Astec, or recapped Bestec units, as these are OEM PSUs that I know for sure were designed well.
Linoleum wrote on 2024-11-01, 02:38:
Indeed it isn't.
In fact, it's usually pointless most of the time, as motherboards often have multiple caps in parallel. So you can never measure just one single capacitor. Also, the capacitance is one parameter. The impedance / ESR is equally important, which is something you cannot measure with a multimeter... and even less so with the cap attached on the motherboard.
That being said, this appears to be an ASUS-built board (which is typical to most HP's). As such, rest assured that the electrolytic capacitors are usually of good quality and unlikely to be bad. Based on the picture you provided, I see black capacitors with "K" -style vents on top, which suggests Rubycon... and probably their YXG series, which was more or less the best low ESR they had at the time. These are very reliable electrolytic capacitors, so unlikely they would be bad.
Unlikely. Tantalums almost never burn out without leaving a (serious) mark on the board.
Reply 7 of 46, by akimmet
momaka wrote on 2024-11-01, 13:43:
The most common failure mode for tantalum capacitors is to fail shorted.
They don't always burn up. Sometimes a fuse or the power supply protection trips first.
Reply 8 of 46, by momaka
akimmet wrote on 2024-11-01, 19:15:
Indeed
Aside from the USB and PS/2 ports, mostly everything else is unfused on motherboards. So good luck looking for blown fuses.
The power supply may trip... or it may not. If it doesn't, then the shorted Tantalum cap will surely burn. However, notice O/P says board powers on (fans come on), yet no POST. If PSU was tripping due to a shorted Tantalum (or shorted any component, really), then the fans wouldn't stay running - you'd get a "blip" of power with most fans twitching for a second or two and that's it. So that's one way to know whether you have a "hard" short-circuit somewhere or not. In rare cases, if the short is on a buck-regulated rail (VRM), the controller for the associated buck VRM may detect an overload and shut down without making the PSU trip. But I find this to be an exception rather than the rule, at least with retro hardware.
Reply 9 of 46, by the3dfxdude
It's not clear that you have a short due to a capacitor to me. If you are truly getting post codes, then that means part of your board is working. That means a short is unlikely, because normally a short across a cap would trip the protection on the power supply.
A burning smell can be many things. ICs can get damaged, burn up... I've seen VRMs go. My son burned up a PNP not too long ago.
I'd look at the original power supply and see if something went bad in there. I'm guessing all the swapped in parts are known working? You can get a meter and check voltages on the power supply and check resistance on rails on the motherboard.
Reply 11 of 46, by Linoleum
Yes, the parts I swapped in are all known working parts.
Bit more info: when removing the RAM I get beeping errors (on top of fans spinning)... But still, no display.
Unfortunately, the smoke and beeping with everything in place only happened once when it blew up... Now, no smell nor anything's getting hot.
PS2 30/286, SBP
Reply 12 of 46, by rasz_pl
Linoleum wrote on 2024-11-06, 00:25:
pull it out, get a magnifying glass and go over front and back looking for fried tracks or discolored components.
Last two dimm pins 84/168 (https://allpinouts.org/pinouts/connectors/mem … -sdram-168-pin/) are 3V power, check if there is still 3V there.
https://github.com/raszpl/FIC-486-GAC-2-Cache-Module for AT&T Globalyst
https://github.com/raszpl/386RC-16 memory board
https://github.com/raszpl/440BX Reference Design adapted to Kicad
https://github.com/raszpl/Zenith_ZBIOS MFM-300 Monitor
Reply 13 of 46, by tanis
Linoleum wrote on 2024-11-01, 01:09:
I've been working on my P2 setup for few weeks...It uses a HP Condor 1 (P2B-VE) motherboard. The moment I was mostly done with t […]
I tried:
3A: Auto Size Cache
28: Auto Size DRAM
The two codes, if I'm reading them correctly, mean that the last successful POST test was Auto Size DRAM, and the one that failed was Auto Size Cache. Have you looked up what that failure means from the BIOS reference?
Strangely enough I had the same symptoms on a Pentium 4 I'm working on . Booted fine after cleanup, added an IDE HD, fans all spin up, no POST beeps at all. I've got a POST card otw, but none of my efforts so far have managed to recover it. We'll see what my codes say.
Reply 14 of 46, by MikeSG
Any gold coloured pins on the cache? Or nearby?
Reply 15 of 46, by Linoleum
MikeSG wrote on 2024-11-06, 10:51:
Isn’t cache on the cpu for pentium 2?
PS2 30/286, SBP
Reply 16 of 46, by Linoleum
Additional clue: the cpu fan header blew up in the process… I just noticed since I’ve used the easiest fan header to reach during my tests.
PS2 30/286, SBP
Reply 17 of 46, by rasz_pl
as in melted?
Shorted fan header would do it, 12V line or with any luck a fuse will be fried somewhere between FAN and ATX connector.
Still this would only break 12V and nothing on this board uses 12V apart from Fan headers and RS232 translators + Asus monitoring chip measuring voltage on all rails.
Reply 18 of 46, by Linoleum
rasz_pl wrote on 2024-11-08, 09:49:
as in melted?
No, sorry! It's in good condition visually. It just doesn't work anymore... Also, I checked all solderings and could not find anything suspicious...
Something also bothers me: there was no heatsink on the chipset. However, I'm pretty sure these things don't burn to the point of going up in smoke... Ugh. Anyways, I am giving up. I've already replaced it...
PS2 30/286, SBP
Reply 19 of 46, by Ujeen
any luck with your issue ? (I'm burning processors here occasionally 😀 , so quite curious what it is in your case)
