First post, by feipoa
- l33t++
Laying around for nearly 15 years, I had several left-over PLLs from a project I was involved in to run my 486 motherboard at more custom Front-side Buses. These PLLs consisted of:
NB3N502DG
512MILF
502MILF
PI6C4511WE
ICS570ALF
ICS541M
ICS542M (this one is a divider)
I decided it would be convenient to solder one of these PLL multipliers onto a protoboard for use on a 386, similar to what was done here: https://migronelectronics.bigcartel.com/produ … g-underclocking
I do not know which PLL part the above unit is using; there are reports from people who have received one of these that the part number has been rubbed off. Most PLL multipliers which can take an external crystal should work for our purposes. I decided to use the 512MILF PLL, which according to digikey, has been discontinued. I believe NB3N502DG will also work since the pinouts are identical. With today's inflation, these chips now cost about $6 USD.
My goal was to get finer tuning in the 80-100 MHz range, thus I am using crystals from 14.318 MHz to 20.0 MHz (20 pF). With these crystals and multiplier adjustments (4x, 5x, 5.33x, 6x) , we can achieve these results in the 80-100 MHz range (and beyond): 80.0, 81.29, 81.92, 85.33, 85.91, 86.70, 87.38, 88.67, 90.00, 92.16, 94.58, 96.00, 97.54, 98.30, 100.0, 102.4, 104.86, 106.4, 108, etc.
The footprint dimensions of the protoboard is 17.75 mm x 10.15 mm, which looks to be smaller than the above reference unit due to not having an overhang.
Some photos of the working prototype:
