First post, by mtest001
Hi all,
My current socket 7 setup is built around a Shuttle HOT-569 mobo and a Pentium MMX 200 overclocked at 225 (3 x 75).
That motherboard accepts AMD K6-2 and the FSB can be configured up to 83 Mhz.
I am considering swapping my Pentium MMX for a K6-2. Why? Just because I can...
Now I am confused with regards to which CPU to get because on this page (https://www.pchardwarelinks.com/569_spec.htm) it says : "K6-2 processors faster than 333MHz may draw too much amperage through the motherboard to be considered reliable".
Should I stick to a K6-2 333 @ 66 x 5? Do you think my board would accept a K6-2 450 underclocked at 4.5 x 75 = 337 MHz?
On the other hand I have found evidences of people running K6-2 at 400+ MHz on the very same mainboard (see https://groups.google.com/g/alt.comp.periphs. … Uwn-N7WM4?pli=1) so really not sure what to believe...
Any advice?
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 1 of 4, by Repo Man11
Jan has a patched BIOS for that motherboard that adds support for the K6-2/3+ CPUs. They have a lower power draw than a standard K6-2 so that shouldn't be a problem. So you could have it setup with a 500 MHz CPU with 256k of L2 cache if you like.
http://www.steunebrink.info/k6plus.htm
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 2 of 4, by analog_programmer
I430TX chipset can do 83 MHz FSB, so you can use 500 MHz K6-2 CXT, K6-2+ and K6-III+ CPUs (83 MHZ * 6 multi (setting for 2 multi) = 500 MHz). For more info and details look here.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 3 of 4, by mtest001
Good advice, maybe I should look for a K6-2+... Much harder to find though...
Reply 4 of 4, by waterbeesje
Some bonus advice. Any K6-2 with CxT core and up will read the 2x multiplier and applies a 6x multiplier.
i.e. 66 X 2 setting will run at 66 X 6 = 400MHz and 83 X 2 will run at 83 X 6 = 500MHz.
Stuck at 10MHz...
