First post, by Mu0n
- Member
I was tired of these unwieldy, not-so-great custom cables I made for my vintage PC gameport. I needed access to a joystick and MIDI out for msdos classics like: X-Wing, TIE Fighter, Zeliard, Rampart, Micromachines, Wing Commander, Descent, Tyrian, etc.
so, I designed my own PCB board to deal with both of those, plus, might as well put those connections in for MIDI in (think sequencers like cakewalk for msdos, or cubase for win95/98) and a joystick 2 for local multiplayer games (ie Rampart, micromachines, etc)
I guess you need a mpu-401 compatible port ("dumb" uart mode is enough) to get the full midi functionality in. SB16 or similar clones in that era and later cards usually had such a port.
this is among my first project pcbs ever; after a couple months of iterations, the final design works with all the use cases I was after.
You can get one here: https://jcm-1.com/product/pc-gameport-party/
1Bit Fever Dreams: https://www.youtube.com/channel/UC9YYXWX1SxBhh1YB-feIPPw
AnyBit Fever Dreams: https://www.youtube.com/channel/UCIUn0Dp6PM8DBTF-5g0nvcw
