First post, by Cursed Derp
Heyyyyyyyyo,
I mounted the disk image file game.gog from Ultima Underworld on gog using daemon tools on windows 98 (after renaming the file game.iso). When I use the origin.bat file, this message comes up:
The attachment 20241118_193246.jpg is no longer available
I've also tried burning the game to a cd-r with the same results.
Is there a way to bypass this error and get the game working?
Any help would be greatly appreciated.
Thanks
I am as smooth as a gravy train with flaming biscuit wheels.
Reply 1 of 2, by badmojo
Looks like you've mounted the disk drive as G: and the game is looking for E:. Either mount E: instead or look in the BAT file you're running and see if there's a reference to E: that you can change to G:
Reply 2 of 2, by Cursed Derp
badmojo wrote on 2024-11-20, 03:10:
Thanks for your answer. Sorry for the late reply.
No references of drives in any batch files. Good idea though
I burned a disk with the game.gog disk image and put it in my real drive e. Then this happened:
The attachment 20241124_180218.jpg is no longer available
Then I tried my real drive d and the original error came back.
I don't know what I'm doing.
Until further notice I'm open to any suggestions
