First post, by BehelitSkull
Hello,
First thanks for dgvoodo2 it is an amazing tool.
I use it to trigger Windows AutoHDR even for DirectX 9 games. And it works 😀 !
My issue is this, i installed dgvoodoo2 for Dishonored Steam version with the unofficial fix patch D1. Locally on my laptop no problem everything works i just had to update ReShade and its effects.
But when i stream the game with Moonlight (Apple TV client) and Sunshine (laptop host) i have a black screen in fullscreen and only the game sound/music working. The gamepad input works. When i press Alt + Enter the game appears finally but in a Window and not centered.
I have default settings in Dgvoodocpl i just chose my graphic card in the menu and put the max memory vram setting (4000 ?). I tried to put the //./DISPLAYX name instead of default but it always change.
For Sunshine i use Virtual Display Driver that is disabled by default in device manager, with scripts/commands that activate it when i start streaming (and that disable the laptop screen) and disable it when i stop streaming. There's also a vsync toggle program that stop vsync when the stream starts, nefcon, Playnite, Playnite Watcher, MultiMonitorTool, Sunshine Virtual Monitor. All come from Sunshine AIO.
When i stream the same game in Steam Link in fullscreen i don't have this issue, but for me i like Moonlight/Sunshine better with only the client screen active and better performance.
And all the games without dgvoodoo2 works with no problem.
Can anyone help me find the issue and which settings to use in dgvoodoocpl please ?
