Reply 40 of 55, by ZeebaEata
Here is my solution for running Innocent Until Caught on freshly installed DOSBOX 0.74
1. Download the ct-voice.drv file from https://drive.google.com/file/d/0ByFEcFBDH6v8 … iew?usp=sharing
2. Copy the downloaded ct-voice.drv file to C:\SOUND\DRV on your DOSBOX's C:
3. Add SET SOUND=C:\SOUND to [autoexec] section of your DOSBOX 0.74 Options
4. Change sbtype=sb16 (or whatever there was) line in your DOSBOX 0.74 Options to sbtype=sbpro1
5. Install and run the game with Soundblaster support!
Reply 41 of 55, by Gamecollector
CT-VOICE.DRV can work w/o DEVICE=CTSB16.SYS and DEVICE=CTMMSYS.SYS in CONFIG.SYS?
Reply 42 of 55, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Each SB model came with a CT-VOICE.DRV on its driver disk(s) that will only work with that model (it checks the DSP version). That is why it's usually necessary to change the sbtype= setting in DOSBox to match the driver for a particular SB model; however, there are hacked drivers included with a few DOS games that remove the DSP version check.
SB16 versions of CT-VOICE.DRV do not work in DOSBox 0.74, but most do work in SVN provided you use the sbtype=sb16 setting. There are later versions of the SB16 driver that require the CTSB16.SYS and CTMMSYS.SYS drivers, and these later versions don't work with DOSBox's internal DOS, although you can boot real DOS in SVN to get it working. In some cases you can substitute an earlier version of the SB16 driver that doesn't require the additional drivers for a later version that does, but you may also need to configure DOSBox SVN to use IRQ 5 for the SB16 (irq=5).
Reply 43 of 55, by MatchesMalone
ZeebaEata wrote on 2017-05-29, 17:27:
Here is my solution for running Innocent Until Caught on freshly installed DOSBOX 0.74 1. Download the ct-voice.drv file from h […]
This worked for me, thanks!
Reply 44 of 55, by keropi
I am messing with the game but I cannot really understand where the SB SFX are heard.
First I tested with my retail CD and a 386DX+SB2 system, ct-voice.drv loaded fine but I heard no sfx in the intro at all
so I moved to dosbox and tried SB combos and drivers from Akuma's pack. No issues loading but again all I get is music in the intro...
so anyone knows if the intro has any sfx playback? or where exactly the sfx playback can be tested?
thanks!
Reply 45 of 55, by ripsaw8080
Rank DOSBox Author
DOSBox Author
AFAICT, there's no PCM sound in the intro, and only a little during gameplay. At the start of the game, when the shuttle lands at the spaceport there is some hiss of thrusters, and if you go out the front door of the spaceport and wait awhile a taxi will go by and honk its horn.
Reply 46 of 55, by keropi
oh wow, that little? I was expecting spaceship noises at least...
will have to listen closer then, thanks ripsaw8080!
Reply 47 of 55, by Akuma
This worked for me under DOSBox:
To prepare the game:
1. Download SoundDriverPack102.7z
2. Create a 'DRV' folder in the 'IUC' folder
3. Extract '/CT-VOICE.DRV/DOSBOX/1.14/SB15/CT-VOICE.DRV' into it.
(this is the most compatible driver, see here)
3. Extract '/CT-VOICE.DRV/DOSBOX/3.07/SB16/CT-VOICE.DRV' into it.
To run the game:
4. SET SOUND=.
5. IUC.BAT
EDIT: Seems SFX effects did not play with the 1.14, the 3.07 however works fine.
Reply 48 of 55, by Akuma
Had some time on my hands today and did some more testing in DOSBox.
These are the CT-VOICE.DRV/DOSBOX drivers from the Sound Driver Pack here.
7.23 KiB
dosbox sbtype matrix
Some of them work, others do not.
DOSBox default is SB16, so I would go for the v3.xx drivers first.
Its also important to note that clone cards have similar problems.
Genuine Soundblasters seem to work fine (thanks keropi 😀)
If you have some hardware and are willing to do some testing, let us know if it works or not. The example video added below has the thrustersound that ripsaw8080 pointed out.
iuc_audio.mp3
141.5 KiB
78 downloads
audio
187.45 KiB
video
Reply 49 of 55, by DOStopic
Akuma wrote on 2021-01-08, 21:07:
This worked for me under DOSBox: […]
To run the game:
4. SET SOUND=.
5. IUC.BAT
Hello, Akuma!
No way to have SFX with a "Roland/Blaster" soundcard configuration! The game won't start with 3.07 (crash before the copy protection screen). If I choose 1.13 or 1.14 the game have music (Roland) but no SFX ...
Reply 54 of 55, by ripsaw8080
Rank DOSBox Author
DOSBox Author
In case you are seeing an "Unable to install sound driver" error message, a reminder that the 3.x versions of CT-VOICE.DRV won't initialize in DOSBox 0.74(-3), you need to use an SVN build.
