First post, by DustyShinigami
- l33t
Hi
I'm having a problem with getting Blood to work correctly under WIndows 98 SE. At one point, it ran fine. Since playing around with the DirectX to try and fix some other issues, the game no longer runs right. I've since upgraded back to DirectX 9.0c, though I don't have any GPU drivers that support 9. I'm using a regular RIVA TNT 16MB. Whether that would solve the problem though... When it was running fine, I was using 9.0c. I just don't think the right drivers were being used. Now, I'll start a new game (have yet to try saving and loading) and the game goes weird. It acts like it's running at one frame per second. On some occasions, it'll correct itself and then run fine, but for the most part, it doesn't. I've recorded a video showing the problem.
Again, it could be a driver issue, but I can't find or work out what the right ones would be to try. Many I have tried have been wrong. I'm currently using the first reference driver for it from here - https://dosdays.co.uk/topics/Manufacturers/nv … a_rivatnt.php#D - which is 1.55. Apart from that, I don't know what else to try. I've already uninstalled the game and reinstalled, and then re-configured the config, but it hasn't helped. The DOS version looks to run perfectly fine though. And while I could just stick to that, I'm too OCD. ^^; It was working fine once before, so I'd like to get it working right again, if possible.
EDIT: I made a mistake. The drivers I linked to were ones I was looking at last night, but not installed. The driver I installed is actually from the old drivers collection from here.
Any ideas or suggestions? Thanks.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
