First post, by TusockyThree68
- Newbie
I've been trying to get a recently found Japanese game called Noah's Ark to run in an Oracle VM. The reason I want to be able to use a VM is so that I can simply give people my VHD file in order to play the game, similar to what is done in the PC-98 emulation community. So far I've got DOS-V 5.0 and Japanese Windows 3.1 installed with the correct drivers for 256 Colors and CD-ROM support (which is necessary because Noah's Ark is a CD game)
The kicker here is sound. The only methods I can find to get sound working under this environment is to run an installer from a driver disc. Unfortunately, there isn't enough conventional memory to get this thing running, so I'm at a loss on what to do. I've tried reconfiguring the config.sys but when I tried that at a previous date, I messed things up, and did something that made it so Windows wouldn't load anymore. So I've attached my config.sys and autoexec.bat files in a ZIP archive in hopes someone can take a look at them and help me out. I haven't done much of anything to them yet, other than run an installer to get CD Rom support, which modified both. I also removed the lines relating to SMARTDRV because I didn't think I needed them.
The source of the sound driver disc image I'm trying to run the installer on came from this video
https://www.youtube.com/watch?v=0Ch6GcRf7o8&t=823s
I've always had trouble with memory stuff in DOS, so any help with this would be appreciated. I'm also open to suggestions if somebody has a better emulation solution they would like to recommend for this. (For the record, this game is available in SCUMMVM but I've heard reports that it doesn't work properly)
