A Pentium comeback
First post, by geg81
And after a few years of waiting, tinkering and frolicking with 8bit stuff and consoles, I finally decided to come back to my second love (the IBM PC) being the first a breadbin C64.
I got a 300gl model 6282 - 690 for real cheap and installed win98se on it. Mind you it’s just a knockoff imitation of the Master Race PS/2 (feels like I was living in Atlantis and then wake up in a mud hut) model 70 I had back in 1991. Still there is that glossy deep green motherboard almost twice as thick than the modern e-waste rubbish.
The 166mmx was replaced by a 233mmx sl29c, and the broken 5.25 cover with a Sony dvd/r I had lying around. In the background you can see a terratec base-1 (a flea market finding), a matrox 550pci that refuses to work with this system (system bios to be updated??) and a SC-55st waiting for my brain to process everything and understand how to proceed further.
The ugly LG is a m1921a which can sync to 15khz and has handy composite and SCART inputs.
Inside there is a 2MB CL5446 and a SB0160.
Suggestions are welcome (time appropriate and not)
Thanks for stopping by
The attachment IMG_0917.jpeg is no longer available
IBM 300GL type 6282-690
P233MMX, 80MB RAM, CL5446-2MB, YMF719 + S2 + Roland SC-55st + RA-50 + MT32-PI
Samsung 900p
d.g.
Reply 1 of 4, by chinny22
Are you using this for dos or Windows games?
It'll make for a great dos PC but many windows games would be better on a faster PC.
The CL5446 isn't a bad card for a P233MMX. It has good dos compatibility which is where you will do most of your gaming.
The SB0160 (SB Audigy) is a good card for Win9x and does have dos support, but your better off finding a ISA sound card if you can.
I always liked that case style, they were still using on PII computers.
Reply 2 of 4, by geg81
Well I intended to use this for DOS and Windows games but I soon realized that there is too much time difference between them. I think I will revert it to DOS + WIN3.1 and ditch the whole 98 thing, or maybe use a SD2IDE and make two or three different installations (of course accepting the machine limits on what can be run or not). I have tried the W98 dos mode but I do not like it, some games are not fully compatible ( i keep getting glitches in lemmings)
So after asking the sound guys here for advice, I will remove the Audigy and install the terratec Base-1 + the SC-55st. I will live with the terrible AD1816 synthesizer until I find a better option.
Samsung 900p
d.g.
Reply 3 of 4, by chinny22
Are you playing Lemmings from within windows or booting into pure dos mode?
I doubt the glitches are related to "dos 7" as it's informally known as. For the most part it behaves exactly like 6.22 with slightly better memory management and FAT 32 support.
But if your installing Win3x then agree dos 6 just feels more right
Reply 4 of 4, by e8root
You can just disable Windows autostart and then you will start Windows 98 SE by typing "win" like you would with Windows 3.11
Win98SE will usually start despite loading DOS drivers - some more sophisticated might however interfere with startup. For that it is best to just create startup menu and have Windows as one of the options. It is useful because sometimes you e.g. cannot load emm memory driver or limit memory to 16MB, etc.
As for computer itself I have something very similar with also P166MMX. Maybe even identical - not quite sure as I don't have it at the hand to check. Ran quite fine from what I remember. I also tested it with Cyrix 6x86MX which incidentally runs at the same 2.5x66MHz = 166MHz settings. Cyrix is both faster and slower. Windows runs quite a bit better but 3D games run visibly slower. I don't think you could put anything better than Pentium MMX 233MHz. Maybe do some OC on it?
