First post, by miller11568
Far Cry 1 gets an environment pixel shader problem depending on my video card NVIDIA GeForce 1650 TI I'm using even if I use dgVoodoo or DXVK. Any help in modifying the Far Cry 1 DLLs or executable to fix this environment pixel shader problem instead of installing the latest official patch?
The attachment farcry1_shaderproblem.jpg is no longer available
Reply 3 of 4, by feda
Yes, I can see the screenshot.
The answer to your problem lies in the other thread you've already made about this.
If it was as trivial as hex editing the executable, someone probably would've done it already.
