First post, by DustyShinigami
Hi
I'm guessing this is very possible, but I wanted to double check, and find out how to go about doing it. Is it possible to get DOS games to initialise some sort of tool/utility every time they load? For instance, I have two games now that require a slow-down/CPU throttler tool in order to work correctly - Theme Park and Indiana Jones and the Fate of Atlantis. Rather than having to load the tool up first before starting the games, it'd be great to know how to get them to automatically do it. I think I read something about modifying a PIF file? I'm not sure if I've seen this file for every DOS game I've installed... And do you just add similar commands like you would if it was an autoexec.bat file?
Thanks
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
Sound Card: Sound Blaster Live Value CT4670
Reply 1 of 22, by sneeker
.Pif files are just for Windows, but there's nothing to stop you using a bat file in the game directory, so for example, doom you could just have a file called d.bat with
@echo off
C:\utils\slowdowntool.exe /switches
call Doom
C:\utils\slowdowntool.exe /turn off
Then instead of running doom.exe, you can just run d.bat and it will run the slowdown tool as well, then quit the tool once you quit the game.
Reply 2 of 22, by DustyShinigami
sneeker wrote on 2024-12-11, 16:53:
.Pif files are just for Windows, but there's nothing to stop you using a bat file in the game directory, so for example, doom yo […]
@echo off
call Doom
Ahhh. Awesome. Thank you. I'll have a play around. Now that I have a new and bigger HDD, I'll need to uninstall all the games and re-install them again. So I can go through them individually and set up a custom .bat file. 😀
OS: Windows 98 SE
Reply 3 of 22, by Harry Potter
What's wrong with just writing the batch files for your games as is?
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 4 of 22, by DustyShinigami
Harry Potter wrote on 2024-12-12, 10:28:
I’m not sure I follow. I do plan on having them all installed under a DOS Games folder this time around, so the directories will be different. Besides, I’ve formatted the old HDD now, so they’re all gone. 😅
OS: Windows 98 SE
Reply 5 of 22, by Harry Potter
I meant to keep the games and simply write the batch files for the games as they are now, but I see that this is infeasible. BTW, if you want to compress the games and decompress them upon access, on an old Win98 system, I had DriveSpace, as the hard drive was too small, but it couldn't compress the hard drive, but I was able to create batch files to decompress the programs, run them and recompress them on exit. If you're using Windows, you can use the console version of 7Zip, but its LZMA2 technique didn't seem to work properly on large files, but other techniques worked propery. For DOS, the DOS version of RAR works fine. I'm working on my own compression techniques, but they are nowhere near ready to be used. 🙁
Reply 6 of 22, by eM-!3
Harry Potter wrote on 2024-12-12, 12:54:
I'm not sure it will help @DustyShinigami as he didn't ask about archiving but it's interesting to me. Do you try to develop your own archiver?
Anyway in DOS I run games and utilities in batch files by decompressing them and archiving only new and changed files after I quit. I use Imp 1.1 archiver as it's faster than zip with better compression ratio. I tried 7z, rar and ace but wasn't satisfied.
Reply 7 of 22, by Harry Potter
I am working on several compression techniques right now, but most of them are very slow and buggy, and the ones that aren't provide a very poor compression ratio and are intended for text. 🙁 And you're right: this won't help DustyShinigami's question.
Reply 8 of 22, by DustyShinigami
@echo off
call Doom
So what exactly is ‘@echo off’. Does that do anything specifically?
I’m in the process of testing this out with Doom, but using Novert. What command would I need if I were to quit the game, if anything? In order to let it know when to disable it after playing.
Thanks
OS: Windows 98 SE
Reply 10 of 22, by Harry Potter
@echo off simply tells command.com not to display each line of a batch file, and when you exit a DOS program from Windows, Windows will by default display the end output of the program and tell you it ended. Just press the close button, and you will end it. Since it is a local configuration, the config will end, and Windows will continue as usual. Does this help?
Reply 11 of 22, by DustyShinigami
Harry Potter wrote on 2024-12-19, 19:46:
It does. Thanks. 😀 Does that work with comments too? Like when you put REM at the start of a command you don’t want to initialise any more, but you still see it?
OS: Windows 98 SE
Reply 12 of 22, by Harry Potter
It does. If you want to reenable displaying of commands, type @ECHO ON. Also, it will automatically reset upon exit of the batch file or when you start a new batch file.
Reply 13 of 22, by DustyShinigami
Harry Potter wrote on 2024-12-19, 20:03:
Awesome. Thank you.
OS: Windows 98 SE
Reply 14 of 22, by Harry Potter
You're welcome! 😀
Reply 15 of 22, by DustyShinigami
I take it there's no option to enable/disable the likes of EMS/XMS per game? That it has to be initialised by DOS first? Most games I've tried are fine with EMS, but I know Beneath a Steel Sky isn't. Would be useful to add some sort of command in a BAT file per game.
Or alternatively...
There is that tool of Phil's that gives you multiple options to choose from. But if you load one, is it possible to go back to that menu in order to choose another? Thanks.
OS: Windows 98 SE
Reply 16 of 22, by Harry Potter
You should be able to change the setup but only if you reboot the system. When in plain DOS, Ctrl+Alt+Del usually performs a warm reboot.
Reply 17 of 22, by DustyShinigami
Harry Potter wrote on 2024-12-26, 20:45:
I guess that would make the most sense. But yeah, I think Phil's custom setup would be the way to go in this case. Saves having to modify the autoexec/config in Windows each time.
OS: Windows 98 SE
Reply 18 of 22, by DustyShinigami
Can’t get Phil’s DOS Starter Kit to work. Is it redundant now? I put all the necessary files in C:\DOS - CD-ROM driver, mouse driver, EMMS.EXE, Himem.sys - but each option doesn’t do anything. 😕
OS: Windows 98 SE
Reply 19 of 22, by Harry Potter
Try https://www.bttr-software.de/freesoft/boot.htm. That site should have some alternate boot programs.
