First post, by Guld
I received an IBM PS/2 model 30 a while back (originally posted here IBM PS/2 Model 30 Restoration (8086 version)). I've cleaned up the boards a bit but I have some concerns about the power supply before I try to plug it in and see if it works.
I'm not all that familiar with power supplies and what may or may not be normal, so any help would be greatly appreciated.
I measured resistance across the outputs on the P3/P4 connectors from the power supply and get the following values. This power supply is completely disconnected from the system, although the fan inside the power supply is still connected.
Pwd Gd, GND 1030 OhmPwd Gd, +12 V 1050 OhmPwd Gd, -12 V OpenPwd Gd, -5 V 1110 OhmPwd Gd, +5 V 1020 Ohm+12 V, Ground 41 Ohm-12 V, Ground 1080 Ohm-5 V, Ground 74 Ohm+5 V, Ground 15 Ohm+12 V, -12 V 1120 Ohm+12 V, -5 V 115 Ohm+12 V, +5 V 27 Ohm-12 V, -5 V 1150 Ohm-12 V, +5 V 1090 Ohm-5 V, +5 V 88 Ohm
So, what gives me pause is the resistance from +12 to ground, -5 to ground, +5 to ground, +12 to +5, and -5 to +5 seem a bit low. Is this normal?
The F1 fuse in the power supply is intact. I don't see any obvious signs of issues that I can see. But I'm sure it has the original electrolytic caps in it.
Any advice on how to proceed with this power supply?
Does it need a load to test or is the fan in the power supply case sufficient?
Anything else I should try to check before trying it?
Any suggestions would be appreciated.
