First post, by ApostolCV
Hello to everyone who love retro hardware.
I'm a happy owner of ASUS PC-DL DELUXE.
I discovered that there is an “improved” model of this board called ASUS NCCH-DL which support Xeon (Nocona).
Both of them were built at famous 82875 (Canterwood) chipset but "South bridges " are different.
Of course question about success modification lower version to bring it ability to start 90nm Xeon.
Reply 1 of 10, by ElectroSoldier
I had a PCH-DL myself, it was a good system but No you cant.
Its not an "improved" model, its a different motherboard.
Reply 2 of 10, by nhattu1986
I think there was a bios mod for the PC-DL to support the nocona Xeon, but i unable to located the bios.
Reply 3 of 10, by ElectroSoldier
nhattu1986 wrote on 2024-12-27, 14:23:
Would it work for the PCH-DL?
There was nothing official to allow it.
Reply 4 of 10, by luckybob
off the top of my head, PC-DL was for the 533 FSB xeons, and the NCCH-DL was the one for the 800's.
I have the ncch-dl when it was new (ish). And it was a FAST board. Those 3.8 chips FLEW.
Reply 5 of 10, by ElectroSoldier
luckybob wrote on 2024-12-27, 15:21:
Yeah I would agree with that. I had some Prestonia core Xeons in my PCH-DL and it was one hell of a system. At the same time I had a MSI K7D Master with some MP 2800+ CPUs and they were amazing systems.
It wasnt until I went with a dual Clovertown system that I had a system that honestly beat either of them.
Reply 6 of 10, by ApostolCV
Unfortunately I only found one broken link to unlock hidden features. No mention of Xeon Nocona support
Reply 7 of 10, by ElectroSoldier
So there is no BIOS update that can make the board support an 800MHz FSB?
Reply 8 of 10, by luckybob
its a chipset limitation, as I recall
Reply 9 of 10, by ApostolCV
luckybob wrote on 2024-12-28, 18:01:
I'm not sure about it.
As i mentioned before both motherboards use same chipset - Canterwood, so limitations should be at hardware level.
Reply 10 of 10, by luckybob
ApostolCV wrote on 2024-12-28, 18:16:
yea, i looked it up, and you're right, but my memory is still telling me its a chipset limit.
