First post, by WhiteKnight
is there any way to speed up/slow down VDMSound? in DOSBox you can use the cycles, but what does VDMSound have to offer in this regard?
Reply 1 of 7, by eL_PuSHeR
When using VDMSound CPU is used at full speed. If you want to speed things down a bit, you may tinker with the CPU advanced options (CAP DOS frequency timer and such).
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 7, by WhiteKnight
thanks for the replies, but what does the Cap DOS timer frequency option do exactly? Also, I would use DOSBox, but the screen tearing in the game is really bad when run through DOSBox...is there a way to enable vertical sync in DOSbox?
Reply 4 of 7, by eL_PuSHeR
Enable doublebuffer option inside dosbox.conf
fulldouble=true (remember to run fullscreen -> ALT-ENTER)
Intel i7 5960X
8 GB DDR4 (2100)
Reply 5 of 7, by WhiteKnight
tried that, doesnt seem to make any difference
Reply 6 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
use guilikoza build.
it has vga_parts set to 1
you will like that 😜
Water flows down the stream
