Mechwarrior 2 install
First post, by nightsky
Hi all, so I finally got my old pc up and running, dos 6.22 with windows 95 dual boot. I’m trying to install mechwarrior 2 from REMOVED, downloaded both the RIP version and the pre installed iso dos versions. Copied them to hard drive but can’t seem to start or install. Any suggestions? What are the exact commands I should be using?
REMOVED
Reply 1 of 2, by myne
Best delete all references to software without a license.
If you don't, the mods will.
How are you attempting to run it?
Ie the exact commands.
I built:
