FreeDOS 1.4
First post, by douglar
https://www.freedos.org/download/
https://www.ibiblio.org/pub/micro/pc-stuff/fr … ributions/test/
FreeDOS 1.4 release candidate 1
2025-01-01 8:42am
The official FreeDOS distribution has a slow update cycle because FreeDOS is already pretty complete. We released FreeDOS 1.3 in February 2022. But we've continued to work on it behind the scenes, including the monthly "test releases" with all the latest updates. And thanks to everyone who contributes to FreeDOS, we are excited to share the FreeDOS 1.4 Release Candidate 1 is now available! This has a ton of new changes and fixes since FreeDOS 1.3. This includes updates to the installer and version updates on many programs including fdisk, format, jemm, ldebug, bwbasic, dojs, dog, nasm, curl, mkeyb, edlin, blocek, htmlhelp, fdnet, more, fdimples, .. the list goes on - read the change log for the complete list. These updates should address many annoying bugs that folks have reported since version 1.3.
Please help test the new FreeDOS 1.4 release candidate. Download FreeDOS 1.4 RC1 and test it out, and report any bugs. We look forward to testing the new version, and including more updates for FreeDOS 1.4 RC2 next month.
Reply 2 of 18, by douglar
RC2 is out
2025-01-22 15:40:20 7zip (Shidel): Initial commit
2025-01-22 11:33:55 project_FDI [candidate] (Shidel): 7zip replacing 7zDec package
2025-01-22 10:51:55 7zip (Shidel): package cleanup
2025-01-22 10:48:40 7zip (Shidel): initial project commit to FreeDOS GitLab Archive
2025-01-20 19:40:22 fdisk (Bernd Boeckmann): version 1.4.3
2025-01-15 21:50:39 fdisk (Bernd Boeckmann): re-trigger v1.4.0 package generation
2025-01-15 21:18:39 fdisk (Bernd Boeckmann): FDISK version 1.4.0
2025-01-15 20:53:27 htmlhelp (Bernd Boeckmann): update english help
2025-01-14 05:56:44 rcal (Shidel): minor restructure for consistency with other utilities
2025-01-13 17:37:17 ambread (Shidel): updated to v20250110
2025-01-13 17:14:45 jemm (Shidel): updated to v5.85
Reply 3 of 18, by douglar
2025-03-01 FreeDOS 1.4 Release Candidate 3 is now available! Please help us test the new version. The new release candidate has a ton of new changes and fixes since FreeDOS 1.3. These updates should address many annoying bugs that folks have reported since version 1.3. Please help test the new FreeDOS 1.4 release candidate by downloading it and reporting bugs.
Reply 4 of 18, by myne
This might be a silly question, but are there plans for if and when bios compatibility is deprecated?
Something like a uefi loader and a seabioslike payload?
I built:
Reply 5 of 18, by jakethompson1
myne wrote on 2025-04-02, 03:09:
That would be something like a universal CSM loaded from disk instead of built into ROM. I wonder how feasible it is, or if CSMs use things too deep like System Management mode to make a universal one.
Reply 6 of 18, by keenmaster486
I wonder if you could use Grub to load DOS on a UEFI-only system.
World's foremost 486 enjoyer.
Reply 7 of 18, by myne
Grub can load dos no problems, but if there are no standard bios services it won't work.
You might as well be trying to boot it on arm.
I built:
Reply 8 of 18, by Cyberdyne
Can it run Windows 3.1x in enhanced mode?
Can it run in a v86 DOS box inside Windows?
Is there a roadmap?
Reply 9 of 18, by carlostex
Meh, wake me up when the Kernel is on version 2.45. That one has the milestones that hopefully will fix the bugs with some games
Reply 10 of 18, by douglar
1.4 is official
https://www.freedos.org/download/announce.html
Package updates:
As you might expect, many programs in the FreeDOS distribution saw updates. Some of the more recent changes include:
  • FreeCOM is the FreeDOS command.com shell. Version 0.86 has a bunch of new fixes, compatibility improvements, and translations, thanks to Jeremy, TK Chia, Emir, Andrew, Yu-Shih, Bernd, Jiří, and others.
  • Xcopy is a standard DOS command that copies a directory tree. Version 1.8b has a reworked recursive copy to not use as much stack space, and uses increased stack size when built on Open Watcom.
  • Move moves a file or directory from one place to another. Version 3.4 has an update to limit stack usage reducing the chance of stack overflow on recursive moves.
  • Fdisk is the program to manage fixed disks (hard disks). Version 1.4.3 collects several important changes since FreeDOS 1.3, including fixing critical errors that could cause data issues when working with many partitions.
  • mTCP is a set of TCP/IP applications for personal computers running DOS. The version in FreeDOS 1.4 has many changes that improve reliability.
  • FDHelp is the content of the main Help system. Version 1.1.0 has been rewritten from scratch by Willi, and includes translations to other languages thanks to several translators.
A few updates didn't make it into the FreeDOS 1.4 distribution. For example, a few programs released updates in the days before the final FreeDOS 1.4 release, like the Blocek text editor (version 1.76) and that was too late to include them. These programs will get included in upcoming monthly test releases.
Also, the FreeDOS kernel is still the same version from FreeDOS 1.3 because the new kernel is not ready yet. Understandably, an operating system kernel is a critical component and will require a lot of testing before we can include it in the next FreeDOS distribution. When the new kernel is available, we'll roll this into the monthly test releases.
For now, FreeDOS 1.4 can't run Windows for Workgroups in enhanced mode, but can run Windows 3.1 in standard mode.
Reply 11 of 18, by Cyberdyne
Make "kernel" and "freecom" perfect.... And then use resources to make all great again. It is still kinda beta thing. I know that ReactOS will alway be beta. It need so much work and is a moving target. But a OS that feature peaked 30 years ago. That has many better "not original" and even better "open source" versions... (E)DR-Dos.
Reply 12 of 18, by Lualb
Cyberdyne wrote on 2025-04-08, 15:15:
Hello! I was reading some things about FreeDOS and it seems to me that it has come quite far, but I still don't understand why it hasn't been possible to implement full compatibility with WfW3.11 in protected mode, really for the first time I would stop using DOS 7.1 and switch to FreeDOS if it were to implement it in its new kernel without any patch, but in the meantime, I will continue using DOS 7.1 with the compatibility it offers with WfW 3.11 in protected mode.
Reply 13 of 18, by carlostex
carlostex wrote on 2025-04-05, 14:25:
So apparently just this year alone 3 new kernel revisions have been released, 2.44, 2.45 and now 2.46. The milestones i was interested in and specifically targeted in 2.45 weren't actually fixed so i don't understand what actually is going on or the strategy is. I'm really hopeful one day i can migrate to FreeDOS once and for all.
Reply 14 of 18, by douglar
https://download.freedos.org/test/
2026-10-01 6:51am
Please help us test the next version of FreeDOS! Thanks to Jerome, our distribution manager, we are able to share a new "test" distribution every month. These monthly releases collect all new changes, and act as a "test bed" to become the next official FreeDOS distribution, and we would like your help to test it. The new "T2610" ("T" for test, "26" for 2026, "10" for October) distribution includes updates to VSBHDA, SBEMU, Himem, TinyAsm, Blocek, Lynx, FDNPKG16, plus several new translations. Since August, we've also included an updated kernel and other tools. Download the test release and let us know if you have any problems.
Reply 15 of 18, by eM-!3
Most of their work is going on AI translations and network package updater. From my point of view kernel is the most important piece of FreeDOS but I don't see anyone is really looking there for feedback. Maybe test releases or not meant for wider public tests?
Reply 16 of 18, by douglar
eM-!3 wrote on 2026-10-12, 17:17:
I think there are some significant kernel changes in release T2608
https://www.both.org/?p=14667
In late June this year, FreeDOS released an updated kernel. Thanks to the hard work of our kernel developers, maintained by Jeremy Davis, the new kernel includes a ton of new work aimed at supporting Windows 3.1 in “386 Enhanced” mode. FreeDOS has been able to run Windows 3.1 in “Standard” mode for years, but “Enhanced” mode requires supporting a lot of compatibility “edge” cases for Windows 3.1. It is no small feat to add this support.
Since that time, we’ve included this updated kernel in every monthly test release starting with FreeDOS T2607 (July 2026). If you install the test release, you’ll automatically install the new kernel. Please help us to test the new kernel; the test release will become the next FreeDOS distribution
Reply 17 of 18, by megatog615
I really wish the kernel was a package I could update with fdnpkg.
Your AI slop bores me.
Reply 18 of 18, by Lualb
Hello! I’ve been waiting so long for FreeDOS to be able to run Windows 3.1 in enhanced mode—with FAT32 support included—so it can compete directly with the DOS 7.1 found in Windows 98. This will allow me to test how Windows 3.1 performs alongside FreeDOS on "modern" hardware. I’m going to download and test the preview version on my 4th-gen i3 PC to check its operation and the new tools it includes.
