First post, by weldum
Hi, I thought it might be a good idea to ask here.
I have a Dell Inspiron Mini 900, it's a pretty run of the mill netbook but since I have it, I want to use it.
However, can't get Windows XP running on that thing, it simply freezes with a black screen with a cursor, Windows 7 will install but since this netbook only has 8GB of storage, the experience is very lackluster.
I've tried various Linux distros to no avail, they work but because of the processor being 32 bit only and its low performance, I can't use very new or heavy software
Does someone has an idea of how to fix the Windows XP issue? Thanks
Specs
Atom N270
1GB DDR2
8GB of flash storage (mounted on a dedicated Mini PCI-E like slot, but electrically compatible with IDE)
8" 1024x600 screen
WLAN and Ethernet
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 2, by BitWrangler
Sure of the resolution? Some Dell Minis had a stupidass 1024x560 or something which is a pain in the ass. Not sure if that's an issue when installing with non-Dell media.
Reply 2 of 2, by weldum
BitWrangler wrote on 2025-01-08, 03:45:
I'm pretty sure as reported by windows 7 and Linux, but the screen is a weird 8.9 inch one
still technically if the issue is the screen, it should be fixed when the netbook is connected to an external monitor I think
