Help with Mounting
First post, by Nightwolf
Hello I could use some help my mount command doesnt seem to work the virtual z drive is fine but ... either the mount command doesnt work or i'm doing it wrong ... if I am doing it wrong would you guys help me and show me what i'm doing wrong
I have my games in my dir called F:\program files\classic games
This is what I'm trying
Z:\> mount f f:\dosprog
Directory f:\dosprog doesn't exist.
I think i'm following it to the letter but I dont know what to do... 😖
You can also contact me via email at ormus_nightwolf@yahoo.com
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Nightwolf wrote:
I have my games in my dir called F:\program files\classic games This is what I'm trying […]
You have games in F:\program files\classic games and you are mounting f:\dosprog ! Why? You must mount your directory with games...
I also recommend you to use DOS compatible names in paths (8 characters name + 3 characters extension, no spaces). It does not matter in mounting, but you cannot use long names inside DOSBOx (to be precise: they are mangled to fit the DOS naming rules).
Mirek
