tony359 wrote on 2025-01-13, 23:20:Yes, I need to check those SMD resistors though I think with a failed one the stick wouldn't work at all. But yes, it's on my li […]
Yes, I need to check those SMD resistors though I think with a failed one the stick wouldn't work at all. But yes, it's on my list.
the ICs are BGA so a bit a pain to move around!
I know Alex of Bits und Bolts tried already to identify the bad ICs with memtest and failed.
One thing I'd like to try is to pull to ground some data lines while memtest works and see if the outcome changes/gets worse/stays the same. If it stays the same it might mean that that data line is the one connected to the bad IC?
I tried with a 10K resistor but nothing changed, I'd imagine I need a bit more to pull down the line. I'll do some tests. if someone has ideas, I am all ears 😀
The socket 370: you are very kind but the truth is that I don't need one! If it's faulty, by all means, the fun is in repairing them! Same for the other boards 😀 The non working IDE might be interesting though 😀
Well in fact it's a problem that the chips are BGA, if they had been normal chips, I think the speech could have been done, of course it's not simple, and for me it's impossible, but I saw in the last videos that you used a trick, with a shaped copper wire, here maybe 🤔 the one in the absence of adequate tools is the solution, but unfortunately 😣 with the BGAs if I'm not mistaken the only system to remove them is hot air, here I don't know if you've already tried, but maybe if you heat them up while memtest works, and you notice the difference, that is, some of the errors disappear, could it be some welding of the BGA to be renewed?
I follow beyond your channels, other channels on the old hw topic, including even Alex from BuB (more others that I think you follow too, one is the one from Phil's Computer Labs), and honestly I don't remember if he made a video on the search for failed memory chips with memtest, but I know that there are other diagnostic programs perhaps even better, and that maybe they can make it clear where exactly the bytes go, but if I'm not mistaken, there is in the Quick Tech Pro a memory diagnostic, which is quite good at finding storage flaws, I used it years ago (several), to find defective DDR RAM banks, but it was several errors, and so I immediately understood that they didn't work, and I didn't waste time waiting for the control to arrive at the end.
There is one thing I thought, maybe you can easily check, on some motherboards, ASUS and the like, there is a jumper to increase the voltage 😬 of the RAM, I don't know if there is something like that on the SDRAM, but if there was a possibility, to raise the voltage from 3.3V to 3.5V, the errors could disappear 🫥???
For the 370 card no problem 😉, honestly I've never tried it, because I have two other identical ones, I remember that it's a VIA chipset ECS, however if you want as a curiosity, I'll post the images here on Vogons (Test troubleshooting MB PC@LIVE), maybe I'll try to do a test on the fly, if visually it's ok.
I forgot, if the double-sided RAM, have the power pins on the same side of the chips, you could isolate the side, with adhesive tape, a bit like you did with the PINs of the slot1 adapters, maybe 🤔 you could have luck 🍀, and half RAM works?
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
