Wolf3D stereo sounds
First post, by winwolf3d
I use VDMSound because DOSBox runs choppy on my machine. It's sad to see that VDMSound is dying away. But anyway, on to my request. Wolf3D doesn't seem to recognize VDMS as a SBPro device and therefore plays everything in mono at full volume (no proximity volume adjustments). Is there any way to fix this?
Processor: Athlon XP 2600+ at 2133MHz
Version: VDMSound 2.1.0 (and 2.0.4 for that matter)
I have tried all DSP versions.
Here's the debug log of the SB events:
@I - 22:21:41.487 - SBController
DSP reset - reinitializing DSP
@W - 22:21:41.520 - SBController
Attempted to read from an unimplemented mixer register (register =
0x26, value = 0x00)
@W - 22:21:41.522 - SBController
Attempted to write to unimplemented mixer register (register = 0x26,
value = 0xbb)
@W - 22:21:41.524 - SBController
0x26, value = 0xbb)
@W - 22:21:41.526 - SBController
value = 0xff)
@W - 22:21:41.528 - SBController
0x26, value = 0xff)
@W - 22:21:47.985 - SBController
value = 0x00)
@I - 22:21:48.027 - SBController
SBCompatCtl released
@I - 22:21:48.153 - SBWavePlayer
WaveOut released
@I - 22:21:48.403 - DMATransferManager
Transfer Manager thread cancelled
TransferMgr released
Anyone have any suggestions?
Reply 1 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
did you try the beta on top of this forum ?
it has sb16 support I think and probably better mixer support as well
Water flows down the stream
Reply 2 of 9, by winwolf3d
I am trying this with VDMSound 2.1.0 (the beta). Is there a newer beta version that I'm overlooking?
Reply 3 of 9, by Qbix
Rank DOSBox Author
DOSBox Author
nope. Thought it had sb16 support. but I might be mistaken.
Probably some one more knowlegdable then me will answer the question (although wolf3d should run allright on your pc in dosbox as you have a fast pc)
Reply 4 of 9, by winwolf3d
I've tried various cycle and framerate settings but haven't been able to find a nice setting in DOSBox. DOSBox does the sound and music perfectly, though. I'll give DOSBox another whirl.
Reply 5 of 9, by eL_PuSHeR
Agreed. I think it's just a matter of a little tweaking. 😎
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 6 of 9, by HunterZ
I don't think Wolf3D has any special support for SB16, but I am pretty sure it will play sounds in stereo (based on where they are coming from in the game) on a SB Pro or SB 16.
I should also mention that Wolf3D runs fine on a high-end 286 or a low-end 386, so it shouldn't take too much horsepower to run in DOSBox.
Reply 7 of 9, by winwolf3d
You're right about Wolf3D and it's stereo sounds. It's just that with VDMSound, Wolf3D's sounds are always full volume and always in mono.
Under DOSBox, I could never get Wolf3D (or rather a mod I'm making based on its code) to run above 8 FPS, whereas I get the max (70) under XP DOS and VDMSound. The mod It is also very playable (~50 FPS) on an 9 year old Win95 machine (exact specs unknown to me.. it's a friend's machine).
I've yet to test it again with the latest DOSBox, so maybe I can get it tweaked a bit better this time around.
Reply 8 of 9, by winwolf3d
DOSBox 0.63 still gives me very jagged game play, but I'll try it out some more.
Reply 9 of 9, by HunterZ
Try a recent CVS build. See my signature for a link. Be sure to read the guide on speeding up DOSBox as well.
